R56 Driving Lamps
Driving Lamps
Hey! I hope this is the right place to ask this...
I am about to order a 2007 MCS. I REALLY like the driving lamps and consider them a must have. My question is, am I getting ripped off by getting them through the dealer? How much more inexpensive are these aftermarket? And, how difficult are they for a person with not much experience to mount themselves? Any input would be great!!!
Thanks a lot!
Thanks a lot!
It's kind of an expencive kit in itself. There's cheaper stuff in the aftermarket. Then again there's also cheaper stuff in the aftermarket, too so...
If you can do the install yourself, you're likely to save at least a couple hundred bucks.
That said, I got the OEM driving lights AND I had the dealer do the install. This was primarily due to a lack of patience. When the car finally arrived I wanted it right away and with all the accessories fitted.
If you buy the oem kit yourself,Roughly ($500 )You get the lights,{ black or chrome} brackets, hardware, modified grille , wiring harness ,relay, fuse, colorline knee protector/ switch. Installation is a little tricky for the first timer, but not impossible for the Diy'r. You will always get help from us that did this install. EDIT.... BDY, I dont think that the brackets that were designed for the R53 will fit the R56 , If you buy a aftermarket kit.
And here's the installation guide I posted a long time ago. I ended up letting the dealers do the install. I was very **** when the driving lights didn't match my stripes, so I had them redo the stripes.
https://www.northamericanmotoring.co...allation+guide
07-16-2020 12:54 PM
Powershift
08-16-2015 05:14 PM
DWooderson
08-10-2015 09:12 AM
