R56 Premium Gas?
#51
Yep, don't say I never taught you anything! (but I still think the hockey game we played with it had something to do with it)
#52
#53
Huh? How do you come to that conclusion? Octane rating is a fuel's resistance to detonation. Higher octane allows advanced timing - once the fuel starts detonating timing gets dialed back. All the fuel should burn all the same unless the ECU goes into dump fuel mode to cool things down.
#54
Since I didn't say that I'm not sure if you were trying to insult me or not?
I have no doubt 93 gives a bit better performance at some level and that's why BMW recommends it. But the bottom line point is the MCS manages "owners manual acceptable 87 octane" vs the "recommended 93 octane" so well you can't tell the difference in mileage or performance, at least on the street. Treat yourself not your MINI to 93 if you feel the difference. Your MCS should think 87 is just fine as it was designed and tested to allow use of 87 and has been tested successfully in the real world by MCS owners.
If a BMW engine engineer told me I will be hurting my engine with 87, I would ask why and listen to his advice. I can imagine them cringing that I would use anything less that the VERY BEST but can't imagine them being any less than proud that they designed the engine to run VERY GOOD on 87.
Though the static compression is high that does not mandate a higher octane. Other factors such as the direct injection and variable valve timing come in to play. The MC engine has variable valve lift that could effectively reduce the compression to zero. No air in = no compression. Even on old-school engines the cam will determine the actual compression not the static compression number.
Any EFI engine has a boat load of sensors that make the car run great or like crap. An engine could be damaged if many of them went bad without a compensating action of some kind. I've yet to read exactly how the MCS engine adjusts for all the variables including fuel. For all I know the knock sensor is an integral part of the system for all octane levels. My understanding is that modern knock-sensors can sense the ping well before harmful levels occur and that the MCS then holds the adjustment so you are not riding constantly on the knock-sensor.
I'm not trying to be an *** (seriously), I'm trying to inform people why running low octane fuel in a motor that produces more than 100bhp/liter is bad. Can you run 87 in your car? Yes. Will the motor like it and/or run as long as it would with higher octane? No. With lower octane fuel it is much more likely that you will have major knock events, even if the ecu has added correction in an attempt to prevent it.
#55
This thread is almost as hilarious as one of the many "how often should I change my oil?" threads. LOL
What I personally do is use 87 octane gas and add a pint of cheap vodka to each tank. Man you should see the car jump off the line after that. And I get about 50mpg too!!!
Now this is the spirit and the request for the mathematicians: could you please provide a graph of costs of consumtion of premium fuel vs regular fuel with 10% Vodka content (in the fuel)?
How would one shot of Vodka for the driver a day effect both consuption and spirit?
I think keeping the driver boozed up will eliminate the worry about oil filter residue and lower fuel consumption as drinking and driving is illegal!!!
#56
That would be something good to prove and quantify. I just think the BMW engineers that designed the ECU know more about it than "any real tuner/engine builder" and so far we don't have much info either way from them other than what's in the owners manual. I'll see if I can find more...
#57
Here are two links, the best I could find. The first is the MINI press release about the new engines and the second about the new M3 V8 engine. Search for "knock". I have no idea if the anti-knock technology is the same in both but it gives an idea of what they can do.
http://www.motoringfile.com/2004/12/...ange_in_detail
http://www.nybmwcca.org/news.php?id=14
I assume you feel(and you may be correct) that the car is setup to not ride the edge of timing when running premium fuel. If we assume that both engines are always pushing the timing to the edge, would one edge be any more dangerous than the other? In fact it would seem that the high octane edge would be more dangerous if you suddenly picked up a bad batch of fuel from the tank. Maybe the car is tuned to an upper limit like 93 octane, then is 89-91 on the edge and wouldn't that be just as bad as riding the edge at 87?
It just seems you have faith that the system will adjust, as designed, or you don't. I have the faith. Try some 87 when you get your car! Get the faith.
#58
I have the 2007 Cooper and had to go into Hassel Mini service, in NY, yesterday. I mentioned to the service advisor that I didn't feel that I was getting good gas mileage. I'm getting 20-22mpg in NYC driving (local).
He said that BMW recommends dropping the octane on the 2007 Mini even though the documents spec it higher. He said 89 would be fine and to see if I got better gas mileage with the drop in octane.
With everything I've read above I can't see how this could be true.
#60
The service advisor felt I would get better mileage with 89.
