R56 High flow filter (CAI) = too much air???
So I just installed the K&N rx4990 (as seen in the "home made CAI" thread)...it fits and sounds great. However, my car lost the "pick up" it had with the stock air box!?!? It just feels less responsive after the K&N filter install....and yes, the scoop is open for fresh air, and filter is never very hot...even after driving 1hr+...
Any ideas???
I'm thinking the air/fuel ratio might be too lean...? Since the turbo already compresses extra air into the cylinder, adding even more air might be overkill??
Anyone have experience or data on this?
Any ideas???
Ray167 (09-19-2017)
nope...everything is connected. Did a sanity check with a buddy.
My educated guess is that maybe by installing the filter directly in front of the MAF, the air-flow over the MAF sensor is altered (somehow distorted) from what it was previously...as in the MAF is not detecting the true amount of air being sucked in. If the vacuume of the intake is strong enough, than the flow (due to less restriction) past the MAF is fast enough for this to be true. Hmmm.
I will be installing a silicone tube elbow between the filter and MAF (therefore altering the flow characteristics)...wonder if that will change anything...?
Anyhow, still puzzling.
That's true, but shouldn't take more than a few minutes of operation. I installed the K&N straight-replacement filter and even with this subtle difference in air flow, the car ran like crap under 2500 rpm for about 5 minutes. By the time I had clocked 10 miles (quick run to the store and back), it was happy as a clam and mixing well.
The engine may operate at in a very narrow band of parameters in order to get the low end torque increases they got out of it.
It could be the lower vacuum resulting from the higher flow rates is outside the operating parameters the ECU needs to make the torque curve they beleive the engine should be running at.
The low end torque may just take serious hit when this happens.
Juse taking a guess here.
It completely resets everything. I have done this to every car that I have owned with no consequences and it allows you to get more off of your modification rather than just bolting it on. If you have a reflash im 95% sure it will erase that as well but will not reset a piggyback or standalone. Your ecu learns off of your driving along with what variables that are playing with your engine.
Until you exceed the volume of fuel that the stock fuel pump or injectors can provide. Not saying that's happening here, but that is a case where too much air requires further adaptation
