R56 programming inside door handle behav.?
HI
Can you program how unlocking works when you pull the door handle? I don't like the double-pull to unlock, then open, I'd rather have one pull to unlock and open. I can't seem to figure this out from reading the manual, and I also clearly do not have strong enough google-foo to search for a previous thread on this (did find a few on failing door lock parts, though
Thanks for any advice,
My understanding is that the only way to do it is to program the doors NOT to lock when you start the car or drive away. This means that you doors do not automatically locked, and remain unlocked, so you only have to pull the handle once.
You can program it yourself via the signal stalk set up.
If you find anything else from your dealer, please let us know..
My understanding is that the only way to do it is to program the doors NOT to lock when you drive away. You can program it yourself via the signal stalk set up.
CORRECT...you can not have lock on drive away and not be stuck with the dbl pull to open. That is how mine is programmed. I don't like the lock on drive away and find the BMW dbl pull to open very annoying.
I asked the MA and he said there is no way to program it any other way.
So you either drive with doors unlocked all the time or you do the double pull? I guess I'm stuck, then, since I do want the doors locked - last night some drunk chick wandering around after a street fest thought we were a taxi.
you can do the unlock on drive away setup and just lock them manually using the toggle switch on the console. However, it does not change the dbl. pull. Once they are locked you need to pull twice to unlock unless you toggle them open first.
I would say I hope it was not one of my children BUT I have 2 sons. WHEW...
All I know is that mine are set to not lock, so I haven't experienced this yet. But I am one of those that isn't in to locking the door when I drive away. It's a weird program setup though. I thought the idea was that you couldn't open the door while in motion, but when stopped and in Park, or nuetral you can then open with a single pull.
on
What !!?? Seriously, that would be awesome
there have been numerous posts here stating that it cannot be done, the Mini could not be programmed to automatically unlock its doors.
there is a thread floating arround here, I think it is "things you did not know about your R56 "...
please keep us posted, I'll be scheduling a premature visit to the dealer soon; if this in fact is now correct....
I haven't seen any reports that says the auto unlock is possible in an R56. And yet a lot of people have been screaming for it. Please share your source.
