R56 Another Comfort Access Question
You've got to program it thru the on-board computer. You can only have it one way or the other....unlock the driver's door only OR unlock both doors. That is, if I remember this correctly from when I set it up.
Yes, that is correct. And when you do that, you can also unlock the driver's door from the passenger side.
I have mine set that way, too. I got used to the double pull, but I've had passengers almost yank the handle off trying to get out, oblivious to the fact a single pull wouldn't handle it.
Something I learned today: If you're standing on the drivers side with the UFO key in your pocket and unlock your door via the handle button, your passenger (without a key) can also press their door handle button to get in.
This of course requires either a quick explanation or a frequent passenger...
I've done that without explanation a few times. Just told my passenger to push the black button and let themselves in before I've unlocked the other side. When they hear the door unlock, they have gotten a questioning look on their face before I explain it.
Not in mine! You sure? I have the option set for ALL doors to unlock. I still need the dbl pull to unlock from inside. It's doesn't bother me though. But you should double check this.
This works for me some of the time but not all of the time.
I've had to manually open the door for my passenger when they weren't able to open the door by pressing on the black button.
You are only able to get out with the single pull if your car is set up so that the doors remain unlocked when driving.
That usually happens when I find the key fob has slipped into a kryptonite container in my pocket.
I guess I need to play with this when I get home today. I found the following.
If I press the black button on the passenger side, both driver & passenger unlocked.
If I press the black button on the drivers side (with doors locked) the drivers side only unlocks.
If I press the black button on the drivers side (with doors unlocked) it locks the doors.
If I press and hold the button down on the drivers door (nothing happens)
Like I said, I need to spend some more time with this....
Minnie.the.Moocher
09-02-2015 01:43 PM
xpunisherx
09-01-2015 11:47 AM
