R56 Wireless key thob
Wireless key thob
I know this has been brought up before, but I can't find the thread.
The keyless ignition thob has a little silver button that pops a valet key out.
What is the purpose of the valet key? I mean there is no keyhole to insert it into to start the car, and you can't lock the glovebox, so what is the purpose?
Not that it really matters, because i never have my car valet parked.
They key is also nice if you want to go swimming, snorkeling or scuba diving. You can leave the fob in the car and just take the key. Also when you valet park, some keychains are difficult to remove the Mini key fob. You don't really want to hand over your whole key chain with your house key to some random valet. So all you have to do is push the release button and give them just the fob.
I'd imagine the valet key would also be handy if the car's battery was to die and you were locked out?
A little off topic, but...
Can anyone with the Comfort Access option get the comfort opening or comfort closing feature to work? Our Owner's Manual claims that when you have Comfort Access you can hold down on the Comfort Access button on the door handle to perform the comfort open and/or comfort close action (where the windows roll up/down and the sunroof vents/closes). However, for the life of me I can't get it to work. The comfort open/close works just fine with the key if manually inserted into the door lock though.
Any ideas???
Also, what happens if you leave the key fob in the car and then get out and try and lock the door with the Comfort Access button on the door handle? You would think that the car would beep at you or something like that to let you know that you've left the fob inside the car. However, ours does absolutely nothing. It simply won't lock the doors and we sit there dumbfounded as to why the doors won't lock.
Strange...
Any ideas???
Strange...
Strange...
Strange...
Yes, I agree that it shouldn't allow you to lock your key in the car (and it doesn't), but it should indeed let you know the reason that it won't lock the door (using a beep or something).
Our neighbor's Infinity makes a nice subtle beeping noise when you try to lock the door with the key inside alerting you to the problem. Seems silly that the MINI doesn't do this.
We find ourself constantly running into this problem for some reason. I can tell already that we're going to end up losing one of our fobs since the Comfort Access option takes away most of our reliance upon it. I'm constantly forgetting that I still need the fob in my pocket when I get into/out of the car. Before we had this feature it was always second nature to have the key in our hands at all time. i.e. if you don't use it you lose it...
Any ideas???
Any ideas???
Any ideas???
Strange...
Any ideas???
Strange...
I'm sure that once things settle down, we'll get into a groove and it will all workout fine (i.e. it will remain in the pocket as it should).
