R56 Daytime Running Lights
Old 01-03-2008, 07:54 PM
PPrince's Avatar
PPrince
PPrince is offline
Originally Posted by drewster
in order to "save" the bulb life of the xenons, anyone here just run the parking lights & front fogs as an alternative DRL? any legality issues with this?
This is my choice about 40% of the time. The rest of the time it's full lights on.
I'm a proponent of DRL, however, was disappointed to learn that with DRL programed on, all the lights were on. As jw34 mentioned, the worst part was that there was no way to turn off the lights while parked with the engine running. Sometimes you got to have those lights off.
  #52
Old 01-03-2008, 08:12 PM
ladisney's Avatar
ladisney
ladisney is offline
Originally Posted by investigator
Of course they are. Now if you want to deal with semantics then you are correct, motorcycles (the physical shape and size) aren't as noticeable. But with lights on, be it a motorcycle or a car, you are going to see it. It matters not whether it's a motorcycle or a car if you are at a stop and a light on a vehicle is coming toward you at a crossroad. You are going to stop or certainly exercise more care in pulling out. The whole point of lights on during the daytime is to be seen as gaston pointed out.
I ride a motorcycle 8 to 10 thousand miles a year. I put a large lightbar with two driving lights on the front and have it on all the time except at night when I select low beam. I've noticed a huge reduction in the number of times I get cut off or otherwise ignored. There's no way to measure accidents avoided, but I'm sure it has made me much more noticeable.
  #53
Old 01-03-2008, 08:32 PM
Benibiker's Avatar
Benibiker
Benibiker is offline
I think most of us agree driving with some sort of lights on during the day is a good thing. I just wish the DRLs on the R56 consisted of just the front lights and you had the ability to turn them off with a switch or something easy.
  #54
Old 01-03-2008, 08:35 PM
n1tr0's Avatar
n1tr0
n1tr0 is offline
Originally Posted by jimmieshear
I can't find that in the current DMV handbook for Cali.
In fact .. I do find on page 41.
DRIVING IN DARKNESS
Drive more slowly at night because
you cannot see as far ahead and
you have less time to stop for a
hazard. Make sure you can stop
within the distance lighted by your headlights.
Use your low beam headlights at
night when it rains. Don’t drive
with only your parking lights on
Oh and this is on the same page a little further up ...
Never drive with just your
parking or fog lights.
Personally, I never have my lights on unless conditions warrant them. If visibility is good, I should be able to see you sans driving lights. If I can't then I probably would need to get my eyes checked
Way to take things out of context there, your little quotes fall under the heading of "When driving in darkness", eg. When driving in darkness, don't drive with only your parking lights on.
If you want to chance it and drive with your lights off because you're too cheap to buy some new bulbs every 4+ years, that's your choice.
My only beef with traditional DRL's is that you get people driving around at dusk and in poor weather with only their headlights on, it doesn't do much to light up your car from all the other directions.
From years of riding and having been hit by plenty of motorists I can tell you the first words out of everyone's mouths is "Oh I didn't even see you"...
  #55
Old 01-03-2008, 08:45 PM
ipeverywhere's Avatar
ipeverywhere
ipeverywhere is offline
Behind the fog light lens there are two bulbs. The top one seems to come on when you turn the lights on. Why can't that be the DRL? That would make some sense. Personally I don't feel the MINI has DRLs. What is has is a programmable setting to "turn the lights on when the car is on". This is lame. I still set this to on and I have Xenons. It does help people see you.
  #56
Old 01-03-2008, 08:47 PM
ipeverywhere
I've always felt that in order to get your license you must take the weekend MSF course. You'll notice bikes after that course even if you never go near another bike. I advise everyone to take it.
  #57
Old 01-03-2008, 09:02 PM
rkw's Avatar
rkw
rkw is offline
I also think it was quoted out of context. In any case, I think it was only stating a recommended practice (which is the case for much of the handbook) rather than describing what is legal. Here is the online handbook (and pdf).
I didn't find anything on this topic in the Vehicle Code, but I did come across on this very curious section that must be out of date or superceded by DOT regulations.
Running Lamps
25109. Any motor vehicle may be equipped with two white or amber running lamps mounted on the front, one at each side, which shall not be lighted during darkness except while the motor vehicle is parked.
Added Ch. 858, Stats. 1965. Effective September 17, 1965.
  #58
Old 01-03-2008, 10:06 PM
Robin Casady's Avatar
Robin Casady
Robin Casady is offline
There were two references to "parking lights" in the handbook. One was under driving in darkness, and the other driving in fog. There were not references to daytime running with parking lights.
However, the online Vehicle Code PDF (almost 1,000 pages) has this:
Lighted Parking Lamps
24800. No vehicle shall be driven at any time with the
parking lamps lighted except when the lamps are being used
as turn signal lamps or when the headlamps are also lighted.
Amended Ch. 58, Stats. 1961. Effective September 15, 1961.
Parking Lamps
24801. Parking lamps are those lamps permitted by
Section 25106, or any lamps mounted on the front of a vehicle,
designed to be displayed primarily when the vehicle is
parked.
Last edited by Robin Casady; 01-03-2008 at 10:07 PM. Reason: added link to California Vehicle Code
  #59
Old 01-03-2008, 11:27 PM
jimmieshear's Avatar
jimmieshear
jimmieshear is offline
LOL I really don't care. I think Robin found what I was going to look for next, the Vehicle Code book. I never did understand why it's so hard to understand why "Parking" lights are called parking lights, and how you shouldn't run them exclusively during the day.
As far as your accidents with motorists, sorry to hear that. I've been on a motorcycle exclusively for the past 8 months as my only mode of transportation in the San Jose area (yay for lots and lots of cars and terrible drivers). Good luck and be safe on your ride.
  #60
Old 01-04-2008, 10:50 AM
daffodildeb's Avatar
daffodildeb
daffodildeb is offline
Something's confusing me. I had a loaner R56 one night, and saw the lights come on as I turned on the ignition. They were barely dim enough to see with on the country road I drove, though. I had to physically HOLD the brights on to get any reasonable light, and that was because the brights wouldn't stay on using the usual forward detent position.
After I returned it, I realized that the DRLs must have been on and these are what I saw go on in the parking lot. So--question is, why would they have been so dim if all the lights go on with the DRLs? And why wouldn't the bright light control have worked in the usual position? I don't have the car now to test it, as it was a loaner, and the dealer said they were all right when I reported the problem, but it doesn't match up with what you all are saying.
Hubby and I both breathed a real sigh of relief when we got home that night...
  #61
Old 01-04-2008, 03:53 PM
Benibiker's Avatar
Benibiker
It sounds like you had the parking lights on. They're the upper half of the fog lights. If your headlights weren't on, that explains why you couldn't keep your high beams on either. Did you try turning on the headlights using the **** on the end of the turn signals? The car may have had the parking lights on when it was last used. If they're left on they go off when you stop the engine and will automatically come back on when you restart it. That's the only explanation I can up with because the DRLs on R56s are just like your normal headlights.
  #62
Old 01-04-2008, 03:56 PM
xof711's Avatar
xof711
xof711 is offline
I simply leave the switch on all the time
  #63
Old 01-04-2008, 05:54 PM
daffodildeb
I don't know--that might have been it, but my husband and I both thought the regular headlights were on based on what we saw in the parking lot. Frankly, neither of us had the "duh" moment of looking at the stalk . We did have SOME light, just not enough to make it safe to go very fast. I'll have to try to see if I can duplicate it with my own car. As I said, it was a very low-mileage dealer loaner, and we just thought it had a defect not previously found by other borrowers.
  #64
Old 01-06-2008, 11:29 AM
shokk's Avatar
shokk
shokk is offline
7th Gear
From the rear, having the rear fogs on all the time has helped on a number of evenings in stop and go traffic, when the SUV driver behind me was too busy on his phone to stop in a normal fashion. The rear fogs are really bright and will light up signs behind the Mini at least a quarter mile away. Does nothing for daytime running, but they sure look cool!
  #65
Old 01-06-2008, 02:06 PM
mystfynyou's Avatar
mystfynyou
mystfynyou is offline
When I was learning to drive my mom made me turn on my headlights at all times, now its a habit to just cut them on when I get in the car. I just do that instead of DRLs. I don't have xenons so bulb life isn't that big of an issue for me. Plus you have to have headlights on with wipers so I don't have to worry about getting a ticket for that. I do notice that in Richmond a lot of other people have DRLs though.
  #66
Old 01-06-2008, 02:15 PM
Chuck W.'s Avatar
Chuck W.
Chuck W. is offline
Originally Posted by Robin Casady
Mine are off. I don't want the Xenons coming on everytime I start the car.
My feeling exactly. Had them programed to come on then changed it.
07-16-2020 12:54 PM
Dsinkster
08-17-2015 03:24 PM
Powershift
08-16-2015 05:14 PM
oldkid6
08-11-2015 08:13 PM
Lt. Dan
08-10-2015 08:23 AM
Quick Reply: R56 Daytime Running Lights
