R56 M14 x 1.25 Wheel Assist tool
Installing wheels on the Mini can be a pain. In the worst case, it takes three hands: two to support the wheel in exactly the right position, and a third to install the first lug bolt. A wheel assist tool helps solve this problem by providing some support and alignment. See below.
The problem is, the M14 x 1.25 threads on the R56 are extremely uncommon. There are no wheel assists in that size. And if you think you would like to make your own, good luck finding any bolts or threaded rods. I've looked all over the web and found nothing.
What to do?
Chuck at metalnerd.com (I have NO affiliation) said that if there is enough interest, he could do a production run of these tools. It's a $10 part in M14 x 1.5, but will cost more in M14 x 1.25 due to low volume. However, the more interest, the more likely he can offer these at a reasonable price.
So ... what say ye?
What to do?
So ... what say ye?
depends on the wheel
My Fikse wheels install as easy as pie. My stock wheels (S Winder) have the wrong size center bore, and simply won't balance on the hub with the right alignment to install the lug bolts.
Having owned three BMWs, and having installed three different sets of BMW wheels on one of those, I was shocked that Mini screwed up the center bore.
on
Hadn't noticed that. In spite of what many people think, finer threads are generally stronger than coarser threads. The shear strength is better because the fine threads leave a larger dia. core than coarse threads. Tear-out strength is greater because of the larger number of threads more than make up for their smaller size. So, BMW probably chose 1.25 pitch for strength.
Coarser threads were generally used to make production faster.
on
Thanks for reminding me....I needed to order one. 12 x 1.5 (for the R53...
This is a great tool BTW.....I've used em for years on my Audi's....
http://www.metalnerd.com
07-16-2020 12:54 PM
08-21-2015 11:25 AM
