R56 What are the minimum octane requirements for the MC and MCS?
91 is strongly recommended. The engine can run on lower but it will decrease timing. Some dealers fill up with 89 for the fleet savings, but for an owner it doesn't make sense.
Just one tip as I see you're a pretty new user and have a couple unanswered posts on the boards. Do a search before creating a new thread. You'd be surprised how many questions have already been posed (and answered) multiple times.
I don't have one yet. Still doing my homework before pulling the trigger.
Very few stations here in NY offer 91 Octane. It's usually: 87, 89, 93. I believe that Sunoco still has the four grades: 87, 89, 91, 93, but the difference between the 91 and 93 is a couple of cents a gallon, even at these high prices. If the manual says premium, use premium. It's at most a couple of bucks each fill-up over regular, and the engine was designed to use premium.
Regular 87 in my MC manual. States will not harm engine but not recommended. As detailed in other threads, engine has a knock sensor to adjust accordingly, more applicable in warmer weather. May effect performance and gas mileage, but not sure anyone has confirmed this with good data. Anyway, I'm using 87 these days. Always used regular my whole driving life, and I can't break the habit.
Problem is that most of the responses seem to be centered around the S and I'm trying to get clarification to see if the MC and MCS have the same fuel requirements.
Yes, the MC requires premium as well. The MC has a higher compression ration that the MCS. So, they both need premium.
The manual recommends: "Super Premium gasoline/AKI 91"
Minimum requirement is 87 AKI.
It also says, "Use high-quality brands" and goes on to say, "Field experience has indicated significant differences in fuel quality: volatility, composition, additives, etc., among gasolines offered for sale in the United States and Canada."
"The use of poor-quality fuels may result in drivability, starting and stalling problems especially under certain environmental conditions such as high ambient temperature and high altitude."
You can find owner manuals for the various new MINI years online at
http://www.motoringfile.com/
on
Read your owners manual! Or look on the gas door! It's printed in both locations. You think BMW/MINI makes money from the gas companies for printing 91 on those stickers instead of 87? You're driving a performance tuned engine, there's a reason your 1.6 liter puts out as much power as comparable engines with 30-50% more displacement.
If you put anything less than maximum octane in a forced induction engine you're OUT OF YOUR MIND!
although the engine can run off 87... it doesnt mean its suppose to. It will effect performance and mileage for sure. There havent been specific tests for the MINI because its common knowledge that by retarding the timing of the motor, you are making it run below peak performance to prevent engine damage. This applies to all cars. If the car requires premium, get premium.
Anyway, my gas mileage in my MC automatic has stayed at 26 mpg for the past three months since I started using regular in December. I was using premium since I got it last May. I didn't know I could use 87 back then without damaging the engine until I actually read the manual.
on
There have been literally HUNDREDS of posts on this forum, even some offering scientific analysis with data to back it up. You DO NOT SAVE MONEY using 87 octane in a car that was DESIGNED to use 91 octane. Your car will retard timing, your milage will go down, and you'll just have to fill up sooner. Your 96 cents you saved by using 87 octane will be a waste.
For those of you that think your gas prices are high outside of CA, please... do a little research before you complain about paying 2.95 - 3.15 a gallon. My most recent gas fill up was for $3.96 a gallon. I haven't seen gas prices under $3 a gallon in over 2.5 years in CA. I have NEVER put anything other than 91 octane gas in my cars (Yes cars... every car I've owned has recommended, and got 91 octane)
Even better, it costs $6.50+ a gallon in most of Europe to fill up. Guess where our gas prices are going?
Get ready for a ride folks, gas isn't going down any time soon. There are far better places to nickel and dime yourself than whether you use 87 octane or 91 octane.
on
In cold weather, will the timing change if there is no knocking? I have no idea how engines work. Just wondering?
If you're driving spirited and it's 40 degrees out, more than likely you're car would be dialing back timing even with 91. I don't think i've ever seen my car run the timing it's programmed to run. I sit and watch timing figures go from 29-30 degrees down to 18-19 when it's warm out (With 91 octane). Even on race gas (100+ Octane) at the track i've seen my car pull back timing when it's warm out. These motors run VERY HOT!
It hasn't cost me more. Sorry for the confusion, as I mentioned, my mileage "stayed" at 26 mpg when I went from premium to regular these past three months. The low mileage is due less to my aggressive driving but to the fact most of my driving is in New York City.
on
Don't forget that you might be causing slow damage that will bite you in the end...
amusing
Greg
