R56 R56 HID install
Not be discouraging, but I've heard without a large amount of money (1-2K, if not more) plus some serious expertise, it's impossible. There's the auto-levelers, washers, higher voltage, very different design... It's not even recommended for one to change the bulbs themselves on the Xenons.
Best of luck
Best of luck
I wasn't saying that I in particular cannot, just going by MINI's recommendation. I'm sure you wouldn't want to have someone switch on the car and lights while replacing the halogens either. However MINI specifies for the Xenons that a DIY replacement is not recommended. Granted that may be BS, I just have no particular desire to find out.
Yea, I know the Xenon bulbs are extremely high voltage. Even so I can't imagine that's MINI's only reason for not recommending an owner to replace it on their own. With the car off and battery disconnected what is the risk?
Getting back to the OP's question, I don't know of anyone who has successfully completed an HID retrofit. Haven't heard of any dealer willing to do it either, and the parts alone are over a grand.
The problem is that if you put HID bulbs in regular reflectors you're going to blind all oncoming drivers. HID lights have a sharp cuttoff pattern so this only happens when you hit a bump or drive up an incline (R56 HID lights will then tilt down to minimize this). I'm assuming the regular reflectors do not have this sharp cuttoff pattern. Your best bet would be to maybe try to find the entire assembly from a smashed up R56.
You would have to buy both HID Mini headlight assembles. Then a HID kit with D2S type bulbs and the correct connector on the ballast for the stock wiring. The ballast would fit under the headlight assembles in the stock location. I would think the cost would be around 2-2.5k. You also wouldn't have to worry about the auto levels or the washers. Plus you would pass inspection since they are the correct housings.
I just purchased an aftermarket HID conversion kit. I've tried them out and they seem to work great, but I haven't finished figuring out the exact ballast placement, for installation.
(fyi, the kit I got doesn't require any wire modification to my MINI, so I can go back at any time).
I expect Robin has more info on this.
Perhaps you are thinking of this:
http://www.danielsternlighting.com/t...dvantages.html
I suspect that an HID conversion kit might not be legal in California without the proper projector lens system and leveling mechanism. Whether you would be caught is another question. We have smog tests, but I'm not sure whether they check headlights. However, If a CHP was blinded by your lights coming at him, he might come after you.
Perhaps the HID kit could be worked into driving lights that were on a separate circuit and only used when there is no oncoming traffic?
All I want to see is an aftermarket HID kit on an r56 MINI. I want to get an idea of where to mount the ballast. I have put HIDs on my cars before without projectors and I like like them just fine, I don't want to hear about how I shouldn't do it. It's my car and I want to put HIDs on it, period.
I don't mean to be an ******* or anything, but you guys are straying away from the subject. I know what I am doing, I am a mechanic and I have installed HIDs before on my cars. You aren't going to convince me not to put HIDs on my car. So if you aren't going to provide me with positive advice, just don't say anything and keep your opinions to yourself.
+1!!! I learned a lot about headlights from this site.
I just took the Xenons off of my friends MCS, and stuck them in mine (stock halogens). Ballast and bulb are hooked up. The connector fits just fine, but when I started the car and tried to turn the lights on, nothing happened. Is there something else that needs to be done that make them work?
JMHO, I usually love the look of the HID projectors on most car, however, I think the Mini is one car that looks better with the standard Halogens. The HID projectors remind me of a 2003 WRX, and just dont look as good to me. That being said the light is a big improvement over the halogens and are a must in dark areas, but a conversion thats not done 100% correctly (leveling calibration) is just dangerous.
Okay, time to play "devils" advocate. He just wants the information on doing it. ENOUGH people have told him that they think it's a bad idea. I'm sure he's at least considered those opinions. But ultimately it's his car.
He's already said (and I quote) "I know what I am doing, I am a mechanic and I have installed HIDs before on my cars." So someone just answer the question! Jesús Christo!
r56turbo... I'm interested in how you do this (although I may not actually do it), and how well it works. Keep us up to date!
