R56 Anyone have a pic of tranny fill plug
D@mn I thought I had alot of miles at 34k. You wont find any pics here but try this link.Look(click) the first diagram.Number six is the fill plug.
http://www.realoem.com/bmw/partgrp.d...30&hg=24&fg=15
oxy thanks
yeah, i'm a therapist and drive about 140 a day. The only thing i don't like is the dealer's prices. But that picture is exactly what i needed to confirm. I just have to take off the tire to access that bolt, and use a tubing to force feed some fluid in that hole. I had one more question, I have the Mini TIS dvd, and it has the procedure to fill the tranny at 35 celsius, and then i went to the Bentley site and they had very similar but one step different.
The TIS said unscrew the fill plug and the drain plug from the pan, then it said put in park and then drive, and pump brakes, and leave in for 2 secs. Check to make sure the fluid drains out from the drain plug, and then retighten.
Bentley site said unscrew the overflow plug not from the pan, but adjacent almost to the pan. Fill the fluid from the fill plug from number 6 that you showed me, until the overflow plug dribbles fluid.
I was going to go ask a tech at the dealership, but no time yet. Have you heard of the proper sequence of filling and checking the level of the tranny fluid?
you always remove the fill plug first, just in case the drain plug wont cooperate.
if you removed the drain plug first and the fill plug wont cooperate... you're SOL
I don't believe the auto tranny has a drain plug or a fill plug. (many bmws do not). in order to change the fluid you have to drop the whole transmission oil pan. you should also change the "filter" listed as strainer in the realoem link.
also don't forget to clean the magnet before replacing it in the pan.
sevin
12
09-04-2015 01:50 PM
ki7hy
08-12-2015 07:07 PM
