R56 Fuel Additives
#26
Old School
Sorry Tag, don't add Slick 50. I know a little bit about Techron as worked for Chevron for a number of years in the research labs. You use your cheap stuff and I will use Techron. See who has the cleanest engine. I'm calling this quits and it's turned childish. Signing off.
I see no reason for that to not be true today.
Stephen
#27
Well, I use Exxon premium pretty much exclusively (since there is an Exxon right near my house) and at 19,000 miles my tail pipes are almost constantly sooty on the bottoms. After a wash, there is always a good amount of carbon on them within a few hundred miles...
Maybe I will switch to Chevron or Shell for a while.
#29
Every other fill up? Crap, I hope we don't need to use it that much. I usually do mine once every oil change (7500 miles).
#31
I use a Fuel additive once every fall before the fuel companies switch to Winter test, and once in the spring when they switch to summer test. Not because of their fuel. but I feel its good every 6 months to clean out the fuel system. and before and after winter seams like the best time.
I base my fuel choices on who is closest when i decide to fill up, I know a few people in the fuel industry and all the fuel comes from the same pipe. its the additives that change not the base ingredient. And as long as your buying fuel from a station with a high turn over, its clean.
#33
To those who say 87 is fine for your MINI - ask your service advisor to make a note in your file that you run 87 octane if you are so sure it's ok.
They will appreciate the "customer pay" repair that'll eventually come.
Alanberto
09-22-2015 07:30 AM
