R56 After 18 months and 20K miles the only quirck that still irritates me
#26
The turn signal stalk works the way it does due to the nature of the turn signals being digitally controlled as opposed to mechanical control. It is cheaper to use a momentary switch than adding a device to simulate the stalk returning back to center after the signal expires.
#27
Going 100% digital has benefits. It costs less to manufacture. It lasts longer. It is easier to repair when it does break. Whether it is actually cheaper to repair is another story.
To add the mechanism to force the turn stalk back to center from a detent would add cost to manufacturing. It would make the system less reliable. It would cost more to repair.
Quick walk through.
1) You press the turn signal through the detent to activate it.
2) It sends a pulse to the computer which tells the computer to turn on the signal.
3) The computer activates the signal and monitors the steering wheel sensor for position.
4) Once the steering wheel has been turned the preset amount of degrees, the computer turns off the signal.
Now, to add something that will allow the stalk to return to center.
You go through the above 4 steps. Now the computer has to tell something to release the stalk. A motorized detent release, as an example. Adding this whole new step adds more complexity to the entire process and will hurt the log term reliability of the system as well. It even adds more weight to the car.
Virtually every momentary switch in our cars does nothing more than send a signal to the computer.
Quick walk through.
#28
#29
Right button? Yes.
That's about it. Just takes a second to think.
On the MFSW - I have one. But I find myself using it far less than I expected. Probably, this is due to much of my driving being over curvy mountain roads and the dials are not often just sitting there at 9 O'Clock.
Turn signals? Lights? Other ***** and dials? Love 'em.
Thanks for the tip about the mute - didn't know that.
Happy motoring
ltjpunk7
09-06-2015 07:32 AM
JPMontes3
08-23-2015 01:26 AM
