R56 Service manual options?
on
Here's the response I got from Bentley.
I would imagine if a few more people email them about this they might make it a higher priority.
Thank you for contacting Bentley Publishers. At this time, we do not have a firm publication date for the 2007 and later MINI Cooper Service manual. Your feedback is and important to us in our decision making process. We will try and get to it ASAP. Sorry I can't be more definitive.
The TIS disc is actually pretty useful. When I had to get my compressor replaced, I looked it up on there and then when it went to the dealer I checked it out and it was right on. So it is very "textbook" for things, but still seems like you need some prior BMW knowledge/tools to really give it a good go. For now, for me at least, it is nice to have for the $13 on ebay
Ok so it does seem to have all the stuff I/you really would want like changing brake pads, oil changes, inspection check lists, but it is just not organized and takes a few tries to find
EDITED
Thank you rkw
EDITED
Thank you rkw
Also, I haven't played around with it enough, but it does seem to be missing all the stuff I/you really would want like changing brake pads, oil changes, inspection check lists, but again I have not looked through it enough to definitively say it does not contain that stuff
I wrote the following concerning the repair manuals for the 1st gen MINI. My comments will probably also apply to the R56 Bentley and Haynes when they become available.
I'm crazy enough to have all three: Bentley, TIS, and Haynes. All of them are focused on procedures for assembling and disassembling the vehicle. If you need information beyond that, you will find them lacking.
For me, getting the TIS was a no brainer -- my copy was $10 shipped. The Bentley covers essentially the same material as the TIS. Photos and descriptions are so similar that I am convinced Bentley simply took the TIS disc and translated the material to book form. The TIS software has an awkward user interface, the topics are not well organized and it is frustrating having to try several paths to find the information you are looking for. Between the TIS and Bentley, I'd say that it comes down to whether you prefer soft or hard copy. The high price of the Bentley is hard to swallow. I think they purposely printed on thick and heavy paper and formatted pages with a lot of white empty space to increase the size and heft of the book to make you feel like you are getting your money's worth.
The Bentley does have wiring diagrams and the TIS does not. However, Bentley simply reprinted wiring diagrams from BMW's WDS service disc and they are very difficult to use in printed form. Moreover, the WDS can be accessed online here (use Internet Explorer not Firefox, and you need to install Adobe SVG viewer).
I also have the Haynes and I like it. TIS and Bentley are essentially same but Haynes was written from scratch and gives a different viewpoint. As a book it is smaller and lighter than the Bentley and more convenient to use. Although the book is much smaller (not to mention cheaper) than the Bentley it covers very much the same material. For electrical work, the Haynes is worth getting just for the clear and redrawn wiring diagrams. See Ian Cull (GBMINI)'s review here: http://www.gbmini.net/wp/2005/11/the...ual_for_minis/
The TIS does have all that stuff. That you didn't find it at first illustrates how awkward it is to find things in the TIS software. For example, do this to get the oil change procedure: Start with Vehicle Identification, then click on Document. For a 2007 R56 S, select Repair instructions ==> 00 Maintenance and General Data (N12) ==> RA 000610 Engine oil service incl. supplementary service (N12)
on
Well, then you have had better luck with the TIS manual than I have.
I got the one for E36 off ebay (listed under E36 I think it was supposed
to have more than that) and it was a non loadable program.
I had the IT people at work check on it for me. No go. I had a friend
that owns an engineering firm with super talented geeks check it out,
no go also.
I ordered the TIS disk for the mini from a member on this site.
Exact same order of events happened.
So it anybody has this thing working I would really like to know
how you got it to work or where you got it.
I've emailed the Bentley place a while back, and sent in a physical
mail card.
no go also.
mail card.
Are you trying to run it on a mac? I know I had issue when installing it first on parallels because I tried to run it off of files copied to a folder, but it must be run from the CD to work. You have to first install the admin program that has the BMW splash screen and should autostart for install. Once the program is installed, you must open it and go under one of the menus (don't remember exactly which one, but there is only like 3 or 4) and find the install TIS. Should work from there
no go also.
mail card.
no go also.
mail card.
Have you tried this WDS MINI online manual, that one is wiring and you must use Internet Explorer (I use version 7) and add a free Adobe Plug-in for it to work.
Also has good online Help site within it.
condor27596, I don't know what to say. I've had two versions now with no problems. I was using a CD-based version I installed 3 years ago, and recently updated to a newer DVD-based version that includes R55/R56 (both cover all models of BMW and MINI up to the date it was published). I didn't do anything special for the installation.
Skip the VIN thing. Just choose by model (R50, R56, etc) and year. Select the latest year listed if your car is newer than that.
Ok so I looked over the program a little more and now I am convinced it is amazingly awesome haha It really does have a ton of things and seems to cover everything. Thanks rkw for showing the repair ==> maintenance section
condor27596,
did you order yours from ebay? If you want I could make a copy of mine and mail it over...maybe figure out just paying for shiping?
condor27596,
Powershift
08-16-2015 05:14 PM
ki7hy
08-12-2015 07:07 PM
