R56 Torque Specs for OEM Bridge-Spoke Wheels
Can anyone provide the proper torque for the OEM light-alloy wheels? My 2009 MCS should be here in a couple of weeks.
Incidentally, what do you remove on the MINI, lug nuts or lug bolts? Most cars I've owned have removable nuts, but I had a TR-3 with removable bolts.
In the 2008 manual, the torque spec is on page 125, under "tightening the lug bolts". It's a little confusing, since it's right after the section on installing the space-saver spare, but trust me - 103 lbf-ft is the correct torque setting whether you're mounting the space-saver or the full-size wheel.
If you download the owner's manual for the 2008 convertible (which uses the same wheels and lug bolts as the coupe), it's a little clearer that the listed torque spec refers to both the space-saver and the full-size wheels.
Torque Specs
I understand what you are saying and believe you. At the same time, I've looked again at the manual and it still appears to be addressing the space-saver spare only. There doesn't seem to be any encouragement or any instructions for changing out the run flats, even if you carried a mounted spare in the back.
Also seems odd that steel and light-alloy wheels would have same torque spec, but I'll go with what you say. (What do I know: my MINI is in the middle of the Atlantic at the moment!)
You're getting good advice here... trust us. Really. I DO know what I'm talking about on this subject... I didn't 5,000 posts ago. But I do now.
So does Scott.
Proper torque has much to do with the bolts/threads and little to do with what they're holding on (steel or alloy)... enough torque that the bolts don't back out... not so much that they strip... if you were putting on wooden wheels, the same rules would apply.
So does Scott.
Wooden wheels - coming soon from Robin Casady.
The 2nd Gen MINIs have M14 x 1.25 threads, and 103.3 lb ft/140 Nm is the recommended torque. The 1st Gen MINIs had M12 bolts, so 80 lb ft is more appropriate. Don't under-torque your M14s.
It is a fairly unusual thread. The standard M14 threads have either fine 1.5 pitch, or course 2.0 pitch. So, 1.25 is unusually fine, which is fine because fine threads tend to be stronger (contrary to what one might think).
I'd need a much bigger lathe, and a whole lot of liability insurance.
blackie
10-02-2015 07:41 PM
Mini'mon
08-16-2015 04:15 PM
