R56 Brake Warning Light
Brake Warning Light
I've driven the same stretch of road 4 times, and 3 of those times the brake warning light has come on and off at the same spots. I think that some radio signals may be tripping it. The light comes on at no other times or places.
Has anyone else had an experience like this? Very wierd.
Yes I bet its the brake fluid level, It happened to me and the small addition of fluid corrected it. Make sure that you use the correct DOT fluid. (DOT 4 ). If that is the case then you probably take a close look at your cylinders to see if there is a small leak, or take it to the dealers for a warrenty check.
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
