R56 Help... Tire pressure light on
Old 11-19-2008, 05:52 PM
Robin Casady's Avatar
Robin Casady
Robin Casady is offline
Originally Posted by pillar
how much would filling your tires with nitrogen cost?
A local tire place charged me $5 for filling four when I purchased them.
  #27
Old 11-19-2008, 06:40 PM
ronnie948's Avatar
ronnie948
ronnie948 is offline
Science world Vs. real world
Miniclubman is probably correct in the science world but in the real world my tire pressure warning did not go off when the temperture dropped to the 30's last night. I will just stick with the nitrogen in my tires.
Ronnie
  #28
Old 11-19-2008, 06:49 PM
fishbert's Avatar
fishbert
fishbert is offline
Originally Posted by woohoo
yeah, I just did a google search re: nitrogen use in tires and there doesn't seem to be much of advantage to using nitrogen.
Actually, if you have nitrogen in your tires, the jet fuel inside of them is much likely to burst into flames in the event of a crash landing.
  #29
Old 11-19-2008, 06:59 PM
toolazyforalogin's Avatar
toolazyforalogin
toolazyforalogin is offline
I was quoted $75 for a nitrogen fill at my dealership!
  #30
Old 11-19-2008, 08:07 PM
miniclubman's Avatar
miniclubman
miniclubman is offline
Ronnie
Yes, all laws of physics are temporarily suspended whenever you turn the key on your MINI.
  #31
Old 11-19-2008, 08:21 PM
pilotart's Avatar
pilotart
pilotart is offline
Nitrogen does not contain any nitro (or jet fuel).
If you are a Costco member (highly recommend that), they have free nitrogen fill at their auto centers.
Your TPM's might last longer with a dry nitrogen fill, as the oxygen in compressed air contributes to corrosion.
  #32
Old 11-19-2008, 09:06 PM
fishbert's Avatar
fishbert
fishbert is offline
No sense of humor.
http://en.wikipedia.org/wiki/Inerting_system
  #33
Old 11-20-2008, 05:24 AM
Peprwhte's Avatar
Peprwhte
Peprwhte is offline
Originally Posted by tambi
33psi??? . The one on my door says 38! {probably coz i have perf runflats}. Wat kind of tires do u have?
I'm running runflats too. If you have a 2nd gen. MCS, I believe it should read 33 psi all around. Maybe you're misreading the label?
  #34
corcoranwtnet's Avatar
corcoranwtnet
corcoranwtnet is offline
But some of us enjoyed it, Fishbert!
  #35
Old 11-20-2008, 05:30 AM
Peprwhte's Avatar
Peprwhte
Peprwhte is offline
Thanks for your help guys.....all is well, now.
Originally Posted by Peprwhte
My tire pressure light came on last night as I was driving home. Stopped, checked all the tires...pressure dead on. Tried to reset tire pressure light by reading the instructions in the manual, but when I went into the info/setting site, then to tire pressure, there was no "reset." I drove the car as the manual suggested but to no avail.
Bottom line, the car is in my garage with no apparent low tire pressure, but the dad gum light won't go off, and apparently won't reset.
Anyone else have this problem? Any suggestions?
Well, I got in my car this morning, and apparently during the night, Mini gremlins got into my computer and fixed the dad gum thing. I clicked on SET/INFO, then to the flat tire symbol, and sure enough, under the symbol there was a "resetting" arrow. I clicked on it and held it for about 30 seconds, then drove away. Two blocks down the road and the flat tire symbol was gone......everytning back to normal. Thanks for all your help, I was really worried that I might have to go to atlanta(120 miles) to the nearest dealership to correct this, but wala.....it's fixed on it's own, and now I know how to deal with it when/if it happens again.
  #36
Old 11-20-2008, 06:03 AM
slinger688's Avatar
slinger688
slinger688 is offline
33 psi for 16" rims
38 psi for 17" rims (MCS with sport package will have a different label on the door)
Glad your problems are solved.
  #37
Old 11-20-2008, 07:59 AM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
Eric (Plug Guy) is offline
My MCS w/17" crowners shows 38 on the label. I hate the RF's and reduced the pressure to about 34 all the way around, better ride for sure. Reset the TPMS and all is well.
  #38
Old 01-07-2009, 02:40 PM
jorrodsa's Avatar
jorrodsa
jorrodsa is offline
I had to fix one of my tires last week... Did the reset once the light came on... it did not work. Checked tire pressure once again and did the reset, and the light is still on... Question... Is there a 'special' way to put the tire back on after it has been repaired? Should've i asked them to do something with the rim in order for the tire pressure light to work properly...? I'm confused and the manual doesn't say much...
  #39
Old 01-07-2009, 03:52 PM
toolazyforalogin
Are all your tires set for about the same psi cold? Once you reset it you have to drive a few miles.
  #40
Old 01-08-2009, 07:21 PM
OkieSnake's Avatar
OkieSnake
OkieSnake is offline
Mine comes on and then goes off every few days or so. Tire pressure is correct. I have just come to accept it as a slightly annoying bug.
07-16-2020 12:54 PM
theblackfalcon
10-11-2015 09:49 AM
JamJam43087
08-16-2015 02:02 PM
Terry Gallentine
08-11-2015 03:31 PM
nomar116
08-09-2015 09:42 AM
Quick Reply: R56 Help... Tire pressure light on
