R56 Fun with plasti-dip
#58
#62
How hard is it to put the headlight housing back together after you bake it and take it apart? Any sealing issues?
Do you think doing stripes with plasti dip would be a bad idea, would they be removable??
I see some cars with moisture inside when they have their lights on, and it looks really bad. Anyone have a problem with that?
To the second question, I don't think it would be THAT bad. Just wouldn't look too good, and if you don't like it, it should come right off, maybe even easier to take off than from other parts.
#64
haha well like I said it wouldnt look the best and I guess it would be a cool temporary striping.
I was thinking, if you plastidip something, and you spray paint it another colour... would the spray paint come off along with the plastidip when you want it off? Hence you can have temporary spray paint? It works in theory right?!
Someone try it!!!
Someone try it!!!
#66
Answers to couple questions;
Joey mod: No moisture issue. Not sure why there'll be any moisture issue anyways. The headlights unit isn't air sealed. As long as you wipe it well before reinstalling, it should be fine. I cannot stress how important it is to wipe the inside to a streak free clean. I had to reopen mine to take care of streaks.
Plastidip comes in a spray can and also in a brushable form. Not sure about streaks on the brushing though.
The paint over the plastidip does come off easily with the plastidip. I did this with my joey mod. I plasti dipped everything and then high temp painted the top eye red. Look under Clubman thread to take a look. It looks great. I painted another test surface and it adheres exactly the same.
#69
almost one-year update: wheels holding up great. lost some of the sheen, but not noticeable until really up close. its usually covered in brake dust anyways.
joey mod started to bubble, right under the xenons, noticeable when up close. i have to re-do with hi temp paint one of these days.
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
USA-RET
10-27-2015 10:42 AM
