R56 Alta air intake
Old 05-14-2009, 06:59 PM
Dwell's Avatar
Dwell
Dwell is offline
Alta air intake
Looking for some feedback for the Alta Air intake
1.) how loud is the BOV?
2.) how does the intake sound?
Thanks in advance.
Old 05-14-2009, 07:28 PM
DChap's Avatar
DChap
DChap is offline
sounds good.... looks good
Old 05-15-2009, 06:51 PM
maacodale's Avatar
maacodale
maacodale is offline
Like NIKE says, just do it. Both of my MINI's have ALTA's intake. Love 'em both!
Old 05-17-2009, 11:16 PM
Porthos's Avatar
Porthos
Porthos is offline
Its worth it. If you are worried about sound then you might as well not modify anything on your car. But the intake is not that loud
Old 05-18-2009, 07:20 AM
Tsar's Avatar
Tsar
Tsar is offline
I agree with previous posters.
Old 05-18-2009, 09:53 AM
Flyinace2000's Avatar
Flyinace2000
Flyinace2000 is offline
How is the install. I might consider doing it in the future.
Old 05-18-2009, 12:04 PM
ecupip's Avatar
ecupip
ecupip is offline
Here is a video of it. The hissing sound after the throttle is released made me not want to purchase it. I would like to hear it in person before I bought it, but from the video it is to loud for me.
http://www.youtube.com/watch?v=9WYAx...eature=related
Old 05-18-2009, 07:37 PM
frashed's Avatar
frashed
frashed is offline
Sounds like a different beast when it's in gear and driving. I'll try get a video of mine up on youtube for a better representation of the actual sound.
Old 05-18-2009, 08:58 PM
MotorMouth's Avatar
MotorMouth
MotorMouth is offline
It is quite noticeable when you have an open air intake. maybe not loud but certainly no where near quiet.
Old 05-18-2009, 09:42 PM
Porthos's Avatar
Porthos
Porthos is offline
The install takes about 30min and is so easy a 10yr old can do it
Old 05-19-2009, 08:08 AM
Flyinace2000
Cool. Thanks for the input. What performace does it deliver? Obviously more air = more power. Is it noticeable/worth it? Does it open a pandoras box of an addiction to upgrades.
Old 05-25-2009, 05:46 PM
sigo's Avatar
sigo
sigo is offline
I wonder the same thing.
Old 05-25-2009, 06:11 PM
RaceTripper's Avatar
RaceTripper
RaceTripper is offline
I have the CAI and the turbo inlet hose. My JCW definitely is more high strung with it installed. The butt dyno claims noticeably improved results. The install is pretty easy. The intake sound and the blow off when lifting the throttle are very distinctive.
My only complaint has been that my red hoses are color mismatched between the CAI and the turbo inlet hose, but am still hoping Alta can get me a match sometime. They offered to swap for black hoses, but that eliminates part of the coolness/show factor so I declined.
Old 05-25-2009, 06:27 PM
risenONE's Avatar
risenONE
risenONE is offline
I don't have the intake, well for that matter, don't have a Mini - just lurking.
But, just wanted you to know the sound that is heard after the throttle is released is the BOV - blow off valve. Hope that helps.
Old 05-26-2009, 04:39 PM
Topmini's Avatar
Topmini
Topmini is offline
heres a vid of mine, ALTA cai, boost tubes + turbo back
Old 05-28-2009, 03:52 PM
Mann of the Hoff's Avatar
Mann of the Hoff
Mann of the Hoff is offline
I thought I saw that I can't fit a Tower Brace on if I use the Alta CAI on my 07MCS. Did I read that correct?
Old 05-28-2009, 03:54 PM
RaceTripper
I have the JCW strut brace with the Alta CAI. I did need to add some vibration damping felt to keep the top of the MAF housing shroud from vibrating against the underside of the strut brace. Otherwise, it works/fits just fine.
Old 07-10-2009, 10:45 AM
britboyinindy's Avatar
britboyinindy
britboyinindy is offline
I fitted tha Alta CAI to my 2009 JCW- easy install. I test drove it for two miles then removed it. I found it really loud, don't get me wrong I like 'loud' but the noise in my opinion gets very old very quickly.
Old 07-10-2009, 10:47 AM
RaceTripper
I thought so too at first. Now I'm quite used to the noise and rather like it.
Old 07-10-2009, 10:54 AM
ALTA_Jarid's Avatar
ALTA_Jarid
ALTA_Jarid is offline
Here is a video of in my car with an ALTA Intake/turboback exhaust.
http://www.flickr.com/photos/3051919...n/photostream/
Here is another video I made from outside!
Old 07-10-2009, 10:58 AM
drewstermalloy's Avatar
drewstermalloy
drewstermalloy is offline
LOVE the sound of that BOV, and the squeeling tires.
Damn, I wish I would have bought an S.
Old 07-10-2009, 12:30 PM
Porthos's Avatar
Porthos
Porthos is offline
Since it was my first performance mod. It is a noticable difference albeit not a lot. You will know that you have an intake.
Old 07-10-2009, 11:12 PM
mdrums's Avatar
mdrums
mdrums is offline
Aren't you just sucking in hot air with these open filter intakes? Nothing seems "cold air" about the Alta intake.
Old 07-11-2009, 08:59 AM
investigator's Avatar
investigator
investigator is offline
My sentiments exactly. The air under that hood is probably well into the high 100's if not more. How it can be cold is beyond me.
Old 07-11-2009, 09:09 AM
RaceTripper
You unblock the scoop to make it functional for air intake directly to the filter. In addition, the existing airbox intake hose running from the front grill is used to feed air to the filter from underneath it. So there are two sources of air moving in at speed from outside the car. I doubt much of the hot air from inside the engine bay makes its way into the intake.
I definitely felt extra power from the butt dyno. And on track, my JCW was very quick.
Quick Reply: R56 Alta air intake
