R56 Anyone put 215-45/17 tires on stock 17x7 wheels?
Old 07-08-2009 | 03:19 PM
pwnage's Avatar
pwnage
With the stock tire size being 205 45/17 the correct +1 tire size would probably be 215-40/17 to keep the overall diameter the same but there is a tire i've used in the past that i really like that only comes in a 215-45/17. Would a 215 fit ok on a 7" rim (fit properly, that is)? I want the side wall to be square and not have that sucked in look like when people put on a tire that is too wide for a rim. If you do the math a 205-45 has a side wall of 92.25mm and a 215 has a sidewall of 96.75mm. So I'm not too worried about the overall diameter playing any real havoc with anything. Any real world experience on this would be appreciated.
BTW, the tire I'm looking at is a Bridgestone Potenza RE070. It is an awesome tire. Long life and great traction on dry roads.
Old 07-08-2009 | 03:32 PM
old81's Avatar
old81
M6
I have 215/45/17 on my 09 JCW Challenge wheels on my 07 R56.
These tires are Nitto Neo Gen. very quiet, good traction and look good. It looks proper and should have been the factory setup, IMO.
In this size my speedo is only 2mph off versus the 3 of the 205/45.
Don
Old 07-08-2009 | 04:09 PM
slinger688's Avatar
slinger688
I have Dunlop Direzza Star Specs 215/45/17 on my stock Mini 17" rims. They seem to work well.
Old 07-08-2009 | 04:48 PM
minimarks's Avatar
minimarks
Been running that size for a long time!!!
Old 07-08-2009 | 05:00 PM
thevelourfog's Avatar
thevelourfog
I'm also running these on Challenge wheels, they're awesome!
Old 07-08-2009 | 07:12 PM
Porthos's Avatar
Porthos
Not on stockers but on my Enkeis and they will fit no prob
Old 07-08-2009 | 07:21 PM
pwnage's Avatar
pwnage
Thanks for all the info. Does anyone have pics of this set up on their car?
Old 07-08-2009 | 07:57 PM
thevelourfog
Here's a closeup of mine, it's all i had on my phone.
Old 07-08-2009 | 08:43 PM
pwnage's Avatar
pwnage
^^^Wow. That's a perfect fitment imo.
Old 07-08-2009 | 08:59 PM
kukaepe's Avatar
kukaepe
I have been running 215/45/17 on stock 7 inch wheels for quite a while now. No problems what so ever. Much better selection of tires in the 215/45 size, I would not hesitate at all, order up the tires you want and mount 'em up.
Old 07-10-2009 | 12:16 AM
Jason Montague's Avatar
Jason Montague
To Go In Harm's Way
I have 215x45R17's also.They are not run flats and what a pleasant difference.They ride smoother,car handles better.I imediately noticed a difference. So now I'm getting OZ Allegrettes,14lbs ea in UT burnt orange.I kept one of the old tires and I'll have it mounted on one of the old wheels which gives me a spare.Driving from Dallas to El Paso there are many places where one is 200mi from nowhere.I'm through with run flats. Jason
Old 07-10-2009 | 12:47 AM
lvspeed's Avatar
lvspeed
Hi Pwnage, our 03 S came to us with 215/40x17 Fusions. Never heard of them either. I`ve been told Bridgestone makes them. They look about as fat as the prev picture shows. Fusions come with a little lip that tries to protect the rim from light hits. Grip wet or dry is just fine and limit easy to feel, smooth to rehook up if you over do it. If you drive in cold weather don`t buy Z rated Fusions. Lengthy warm up needed.
07-16-2020 12:54 PM
Rgoodwin
Tires, Wheels, & Brakes
04-21-2017 10:56 AM
JamJam43087
08-16-2015 02:02 PM
Dashdog
08-10-2015 06:17 AM
jcb-memphis
08-08-2015 11:09 AM
Quick Reply: R56 Anyone put 215-45/17 tires on stock 17x7 wheels?
