R56 When do rotors need replacing?
I am about to replace the rear brake pads after 46k miles - how do I know if the rotors need replacing?
Also, there are not many vendors for rear pads for the R56. Prices seen to start at $56 at Napa, run around $124 for Carbotech and OEM are even higher. Suggestions?
Great question....
I "wrench" alot on my Jeep and other's (many of us have different axles and such from other manufacturer's on our "junk") and usually all it takes is removing the rotors and taking it to one of your parts stores that will turn them for you.
WITH THAT BEING SAID! On my VW Jetta 2005.5 TDI, VW deliberately made the rotors "lightweight" and turning them is next to impossible...not impossible but I ended up having to replace them. I am NOT sure on the MINI if the rotors are "turnable" or not....wish I could help on that. There is a spec, not sure where you would find it other than here or your SA, on how much needs to be left on the rotors before they have to be replaced.
Not much help but might give you a start FL!
Regards,
Mike
Regards,
Mike
Check out www.mimimania.com for a huge selectiom of oem +++ pads and rotors.
Right in line with my VW experience....I would assume it would be similar on the MINI but unsure.
on
Outmotoring.com has hawk rear pads for the 56.
http://www.outmotoring.com/mini-coop...rake_pads.html
I have Carbotech 1521 Bobcat pads front and rear pads on my 2007 MCS. I like them a lot. Brake dust is barely noticeable (unlike the OEM that covered the boot and wheels in dust), they brake well (better feel than OEM, IMO), and they are supposed to be easy on rotors. I got them from AutoXCooper.
Thanks for the tips.
I now have a question on decoding the indicators on the dash. A couple of weeks ago the "BRAKE" light came on and the service indicator had -100 for the rear brakes. I assume this means the pads are due for replacement and, as there is moderate life left, I am not rushing but will get round to it soon.
First question: when I start the car, the "BRAKE" light is on and initially the Service indicator is on. After a few seconds it changes to a red picture of a car on a lift which then goes away after a minute. The manual says that having the "BRAKE" light on with the red car on a lift means the car's electronics have failed and it should not be driven. I am guessing that is not what I have as something that serious would not go away after a minute. I assume this is just telling me about the brake wear as I started to get that display at exactly the time the miles for the rear brake started counting down. Am I right or is there a bigger problem?
Second question: does this indicator mean I have to replace the wear sensor in the brake pads? How do I reset the system after replacing everything?
aldito2
11-25-2015 09:33 PM
squawSkiBum
10-02-2015 09:21 AM
thebordella
08-31-2015 01:37 PM
