R56 Thumbdrive in USB - Always On??
Hello,
I just used the USB port in my Cooper for the first time. Put some songs on a thumbdrive and plugged it into the USB port in the Cooper and it works great!! Great sound and easy to navigate through the folders/songs.
However, I noticed that when I turned off the radio the light on the thumbdrive was still on. I removed the key, opened the door, and still the thumbdrive light was on....
Is there power to the USB port, and therefore to the thumbdrive when plugged in, at all times?
I've read here in the forums that the vehicle's computer has a memory that lasts for a short while (maybe up to 30 minutes or so??)...does the computer keep the drive active for a while to keep the song lists available and then shut down after a certain period of inactivity?
I was hoping to keep the thumbdrive plugged in all the time so it would be handy when I jump in the car....if there is a power draw all of the time I'm not certain I want to do that.
Any thoughts?
thanks,
Brian
Any thoughts?
thanks,
Brian
on
The Thumbdrive will continue to flash or remain on (depends upon brands and I have a couple that will do one or the other) for some time after you've turned the car off and walked away. My radar detector is wired to a similar circuit and if I make a quick run into the grocery store, it'll still be "barking" at the auto door opener when I come back out.
If you want to check on it to see if it's still on after a while, leave your keys in the house and walk out to peek at it after about 30 minutes. If you've got the comfort access, it'll power back up when you get near the car and if you don't, it'll power back up as soon as you unlock the doors.
gar56
11-15-2016 06:41 AM
Navigation & Audio USB stick keeps repeating same folder
Wombat Pie
Navigation/Audio
10-05-2015 08:00 PM
leonardogia
09-19-2015 12:25 PM
