R56 cold start
cold start
I've been carpooling, which means Mini sits in a park and ride all day. When I get back the engine is cold. The park and ride is right off the interstate, whch means that I'm at highway speed in less than 30 secondsafter starting the car. Is it ok to do this or should I let the engine warm up a bit? Mini sat over the weekend and it got down to around zero. The engine light came on for the first time this morning when I started the car, and then went right off. Made me wonder if I need to wait a bit before driving on a very cold engine.
on
You might want to take a short "excursion" on surface roads before hitting the freeway. In any case, try and keep the revs low (but don't lug) for the first several miles.
Another thing that would be helpful is to use something like Castrol Syntech 0W-30 European Formula oil when you do the oil change. This will be a little thinner at low temps than 5W-30.
One reason car manufacturers say to not let modern cars to warm-up is about keeping emissions down. The longer a car sits idling, the worse it's emissions to miles driven ratio is.
Here is what I do, in both of our generation MINIs at start-up. Start the car, then adjust the seat, mirrors if needed, get seat belt buckled, get iPod playing, set climate control to what is needed. This all takes a minute or 2, and allows oil to be pumped, tranny oil to slosh around a bit, and the seat heaters to take the edge off a little. I'm all for not polluting, but more pollution is created if you need to replace the car before it's time should be up, than to let it idle at start-up (in cold temps) for a couple of minutes.
Mark
Mark
It doesn't take long for the oil pump to distribute oil to the engine. Problem is, when the oil is cold and viscus, the pump may not be able to supply as much oil as is needed for higher revs. That's why you want to keep the revs fairly low when the engine is cold.
Driving at moderate speeds is the best way to warm up the oil.
Another reason is that carbon build-up from idling for long periods can affect engine performance.
Mark
The point was, what's true for your '03 may not be true for 2nd Gen MINIs. You had not problem with carbon build-up. It seems that the new engine does.
07-16-2020 12:54 PM
alistaircookie
10-08-2015 10:52 AM
