R56 1st Seafoam: 2010 Justa
After much reading here, I decided to do a Seafoam tx every 3000 miles on my Justa, even though it allegedly does NOT have direct injection. (Just hit 3K today.)
Following a video I had watched here, I poured about 1/2 a bottle (6-8oz) into the valve cover breather tube while having an assistant hold the engine between 2-3000 rpm.
It smoked greatly for about 5 min and eventually cleared out. (After getting the full amount in, I immediately reattached the breather tube to the valve cover.)
I then read further on the bottle which suggested pouring it in and letting it "soak" in, with the engine off for 5 min, then restart and clear it out.
Anyone here want to comment if this may be a preferable method to what I did?
Thanks,
DOC
Thanks,
DOC
DOC, It's too late now but it would have been interesting to "see inside" the combustion chamber (pistons, head and valves) before the Seafoam treatment. Inasmuch as there was little chance of carbon buildup at such an early stage, it's unlikely it would have made any difference if you had let it soak.
Although I have used Seafoam in my gas tank, I have often wondered if any independent laboratory has actually tested this product. I understand it would be time consuming to remove the head, examine appropriate surfaces including valves, of an engine with carbon buildup. Then reassemble, do the Seafoam treatment and follow with another tear down.
I hope someone can refer us to such a study that has been performed. If I sound like a "doubting Thomas", perhaps it's because I am.
I hope that by questioning this I haven't offended those who swear by Seafoam.
We can discuss the diet pills that burn "belly fat" on another forum.
I think a seafoam treatment can never hurt just to make sure your valves are clean. It's still cleaning out gunk and buildup, even if it doesn't accumulate as much in a Justa as it is in an S.
Just my 2 cents...
Has made a huge difference in the smoothness of idle and the way the engine ran on some of my cars in the past that were bought used in the past, so I have to think that even if no one's done a before/after tear down and inspection the stuff does make a difference.
Sorry to resurect this thread, but i figured it was better then starting a new one
I have an 07 mcs which has 52000 kms on it now and i could swear i feel like the engine is down on power and less urgent im thinking of doin a seafoam like treatment.
Unfortunately i cant get it here, is it ok if i use ATF instead?
I just had the plugs and oil changed at 50,000 if i do the treatment do i have to change them both again?
First of all, I'd strongly suggest that you do a search for "Seafoam" in the "Second Generation Minis" - "Stock problems/Issues' section. You'll find more than you wanted to know about how to use it and what you can substitute for it. That said....DO NOT USE ATF! Don't know where you are, but you can use any product for fuel injector or carburetor cleaning that is designed to be added to your tank or down through a carburetor. Prestone, Gumout, STP, Redline, and many others make these products. Use it like yetti 96 describes above. I like to reserve about 1/4 of the can to use as a "flush" after the soak and second startup. With your mileage, you might want to consider 2 treatments.
Cheers Jon
Cheers Jon
EVMini
09-28-2015 10:20 AM
