R56 Parking brake should hold your car with 3 clicks
#27
I wonder if the 3-clicks is really just a service spec, and not a spec for customers? I mean, that MINI specs that the mechanic must set the parking brake at 3-clicks before doing any adjustments.
#28
Well, you guys sent me out to the car to count clicks. Three clicks put the lever at it's top-most position. I've always pressed the button in when lifting the lever, so I've never heard any clicks before today. Now I need to go count clicks on my other cars' handbrakes. I've never heard them click either.
#29
I bet that is where it is set after adjustment, so it will not drag...
Bet once the cable stretches a bit...it may/may not hold the car...like on a hill. etc.
#30
Although my coope's an automatic, I'm still in the habit of applying the hand break everytime i put it in park-I don't count the clicks but can hear them, and mine feels like it won't go past 2 clicks, so i don't try to pull it any harder-plus after 2 clicks, the "brake" light comes on in the screen above the steering wheel, so i know it's activated.
#31
The MCS is the first car I have ever owned with a manual transmission where the engine will not hold the car on a slight grade without the emergency brake. It surprised me one day when it started rolling into my yard after I parked it in 1st gear without the e-brake applied. Every other MT car or Jeep I parked in the same spot never rolled from there without the emergency brake applied.
#32
Whoa - That's scary for San Francisco and Seattle MINI owners and any other hilly citys.
My folks have a level garage floor with a steep driveway. This happened at least 2 times I can remember over the years, seems like to a '64 Corvair station wagon and a '70 Maveric that 8+ kids learned to drive in. They rolled out of the garage, down the 100' driveway missing the rockery and row of pine trees. across a busy street and into the woods. Passing motorists stopping and pulling them out, and no damage that I can remember.
At any rate, I always set an auto in park, a manual in 1st and set the parking brake.
#33
That light is only showing the e-brake is not fully released to keep people from ruining their brakes... it does not guarantee enough pressure has been applied.
The flywheel could be glazed, or the clutch iself could be worn or glazed...
#34
#35
So, park your car on a hill and wait and watch... it may do the same thing.
#36
#37
Recently replaced OEM rear pads with Hawk pads on my '08 Clubman S. Noticed noise/slipping on occassion with e-brake engaged, but didn't pay it to much mind. A week or so ago, parked in grocery sytore parking lot, bit of a slope. Came out, car gone!!! It had rolled 50-100 feet, miraculously not hitting any other cars in the lot, and into a concrete post at the bottom of a light pole. Bummer, scratched the bumper on the drivers side and put a crack in the plastic. I'll live with it, but in the habit of setting the gear along with the brake from now on. Thought maybe there was an adjustment needed, but maybe the new pads are different enough from OEM to slide?
#38
07-16-2020 12:54 PM
08-11-2015 12:34 PM
Accessory Products
08-11-2015 12:19 PM
08-11-2015 12:18 PM
