R56 Noise when cold
Noise when cold
Do any of you guys get a noise when hitting bumps from the front drivers side? Kind of sounds like something is loose or moving around. The slightest bumps will trigger it. It seems to only happen when starting up below 20 degrees or so. I had it at the dealer take a look but they could not hear it that day.
Some days it happens and other it doesn't. I am baffled! I checked for anything loose up front but could not find anything.
I think I have that. Its a vibrating/knocking sound like there's something loose and def on the driver side. Haven't taken it to the dealer since I've lost trust in them. I hear it mostly after a cold start and depending on the severity of the road bumps thereafter. I don't have sunroof either. lemme know if you ever find where it's coming from.
Supertractor3
04-07-2017 11:16 AM
