R56 How To Keep The Sport Mode On All The Time?
Old 01-22-2011, 09:21 AM
jak112460's Avatar
jak112460
jak112460 is offline
I have an 07 S. I would like the sport mode on all the time instead of having to turn it on at start. Is there a way to do that? This is my first post here so forgive if it is adressed elseware.
Old 01-22-2011, 10:16 AM
Chinoo's Avatar
Chinoo
Chinoo is offline
you need to install a mod if you want to keep sport mode on all the time, there no way of doing this without that mod. here is what u need http://www.outmotoring.com/mini-coop...mode_plus.html
Old 01-22-2011, 10:39 AM
jcauseyfd's Avatar
jcauseyfd
jcauseyfd is offline
Do a search here and you can find instructions on building and installing the mod yourself as well.
Old 01-22-2011, 10:46 AM
slinger688's Avatar
slinger688
slinger688 is offline
I have the one from fes and it works well. Easy to install.
Old 01-22-2011, 10:50 AM
ballandchain's Avatar
ballandchain
ballandchain is offline
Cheapest way!!!! Get in, sit down, point finger left of stick shift, depress button. Saves $50 towards other mods......
Old 01-22-2011, 11:15 AM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Yes the FES module is the easiest thing to do.
Old 01-22-2011, 11:44 AM
automan21's Avatar
automan21
automan21 is offline
so true
Old 01-22-2011, 11:53 AM
jcauseyfd's Avatar
jcauseyfd
Yeah, but it is very unreliable.
Old 01-22-2011, 12:01 PM
ballandchain
I don't know about your finger but my finger is about as reliable as they come. Now, the memory that controls the finger is another story.
Old 01-22-2011, 01:56 PM
Finner's Avatar
Finner
Finner is offline
This question has probably been asked and answered before but I'll ask it anyway. What impact if any does the sport button have on MPG? I would think there is some impact as rpm is higher under normal driving. True?
Old 01-22-2011, 02:26 PM
Augie05's Avatar
Augie05
Augie05 is offline
None. It just changes throttle response and steering effort. Unless you tend to floor the gas pedal more with sport mode engaged. I never drive without sport mode.
Old 01-22-2011, 03:12 PM
Poppa Bear's Avatar
Poppa Bear
Poppa Bear is offline
+1!!
Old 01-22-2011, 03:52 PM
Finner's Avatar
Finner
Finner is offline
My finger forgets to press the sport button occasionally. But usually before I go to far, my finger seems to find its way to press the button. I never really did any comparison of MPG with and without it, just wondered. I figured if there was a difference, it was minimal.
Old 01-22-2011, 04:45 PM
jcauseyfd's Avatar
jcauseyfd
If you have an automatic, the sport button can change mpg because it changes the shift points for the transmission.
In a manual, the only change in mpg will be because you drive differently.
Old 01-22-2011, 08:15 PM
Finner's Avatar
Finner
Finner is offline
Good point! Higher shift point impacts me as I have an auto tranny. But I dont think the mpg impact is significant. At least not enough to keep my finger from finding the sport button.
Old 01-23-2011, 04:39 PM
MCS Fever's Avatar
MCS Fever
MCS Fever is offline
Driving down the freeway all day in a 5th gear at higher RPM = MPG sacrifice. At least on 60 MPH roads I know ours never shifts fully up to 6th gear for the auto tranny.
Old 01-23-2011, 05:23 PM
Finner's Avatar
Finner
Finner is offline
My Justa does the same. I wonder why when cruising on the highway with auto tranny and sport button on, it doesnt seem to ever reach 6th gear.
Because of that I usually turn sport off whenever doing highway driving.
Old 01-24-2011, 09:47 AM
isthar's Avatar
isthar
isthar is offline
by design, iirc, sport mode will prevent the auto from ever entering 6th
Old 01-24-2011, 08:47 PM
brohammer619's Avatar
brohammer619
brohammer619 is offline
I did one fillup with the sport button on, I love the pedal response, and one fillup with it off entirely. I got ~26.5mpg with it on, and ~29.5 with it off. I have a 09 MCS manual. I know it just changes the way the pedal responds, however it's much easier to drive 'spirited' with the sport button on and when I'm driving to work on the highway it's easier to ease onto the gas pedal without it lurching forward with slight touch of the pedal with sport off. It certainly is a lot more fun with it on though
skld (04-14-2023)
Old 01-24-2011, 08:58 PM
DneprDave's Avatar
DneprDave
DneprDave is offline
If you put it in sport mode, with the automatic in manual, you can just bump it up into sixth gear when you need it.
Dave
Old 01-24-2011, 09:12 PM
jak112460's Avatar
jak112460
Is this thing easy to install and will I have issues at the dealership?
Old 01-24-2011, 09:13 PM
jak112460's Avatar
jak112460
What is start/stop engine control? Maybe I'm just not understanding something.
Old 01-24-2011, 09:38 PM
ballandchain
I wonder if the change in milage comes from actual changes in the system or just due to having the extra power on tap and using it more than usual.
Old 01-24-2011, 09:59 PM
brohammer619
hard to tell but if I had to guess it'd be the fact that I just drive more on/off with the sport on, whereas it's smoother with sport off
Old 01-25-2011, 05:28 AM
MCS Fever's Avatar
MCS Fever
RPM dude - the engine fires at every piston every time they come to the top - think about it - fuel is needed for every revolution - more revolutions at a given speed - more fuel.
Quick Reply: R56 How To Keep The Sport Mode On All The Time?
