Good Morning all Mini owners& fans my question today is when you take your tires off to rotate does it off set your tire pressure sensors or do the sensors come off with the tires THANKS for your feedback MINIINHD
To elaborate a little bit, the sensors are inside the tires. Check air pressure if you can, make 'em equal if you can, reset the tpms if you want to (easy to do) but not necessary unless you get a light. Continue to motor. Good luck.
