R56 Justa 'bout had it with the high engine temps
Does anybody out there know of a way to bypass or "parallel-in" electrically,
in order to bypass the ECU's fanatical control on the engine thermostat?
There's gotta be a way to run this platform below 200'F without having the
AC on MAX all the time. My concern is primarily for the engine oil. I suspect that even the mightiest Mobil 1 or other 5W 30 synthetic is going to break-down at constant temps of 220.
If the ECU is "looking" for a load / no-load condition before "deciding" to energize a relay, then fine, there's got to be a way to provide a dumy-load to the ECU while controlling the thermostat from elsewhere e.g. a thermo-switch to the actual relay coil.....or something. I will entertain any ideas. I've just kinda "had it up to here" with the little engine running constantly at high temps (like well-over the 212'F required to boil water).
I'm only a 50,000 mile Mini driver, not a motorhead, but still an enthusiast. This seems like a great forum - once you weed-through the complaints. What I'm looking for is yet another mod. Done several to my little justa, and other than my concern for the engine's lifespan due to running hot, love the little thing, absolutely love it - no Prius envy here. Please offer help if you can.
Contra position to post logic and some replies; oil temp not = water temp
Yes, I know about the water temp. Mine runs in the same 105 degrees C/220 degrees F type range lots of times. Not concerned about it in isolation, and expect with summer heat loads the thermostat is more likely to go full open anyway, while now in winter it won't. Have a similar system on a high end Audi, and it can dump the thermostat to full open and force a fast coolant temp change almost on demand (in that case a quick 15 degree swing). The higher temp gives better fuel economy meanwhile.
Several of the posts seem to connect the water temp to the oil temp directly. In fact, I would generally expect a fully warmed engine to run above 220 for the oil system. Don't have a oil temp gauge in mine, but wouldn't surprise me to see 250 degrees frequently, and even 275 if it is working hard. In fact I would affirmative definitely want it to rise above 212F just for starters, because I would want to boil off any water in the oil that accumulates with normal engine function and cold-hot cycles. And if the R56 has things like under piston oil sprayers to cool them given the turbo, plus the oil at normal other high heat transfer points like around the head and at the exhaust valve guides, I can guess the oil in these things does warm up pretty well.
200 degree water temps is not hot, just drive the car and stop worrying about it. Higher temps get the best gas mileage and keep contaminantes evaporated out of the oil.
Back in 1988 I had a VW Jetta GLI 16V that I thought had high engine temps and it never left me stranded. It had a digital oil temp gauge and it woud read up to 260 degrees on a hot day. I don't own that car any more, but I still see it driving around occasionally.
OK, OK, I get it. Let it run hot. Thanks for all the INPUT!
And just fyi richardsperry vbmenu_register("postmenu_3233727", true);
I do have guages for it, it doesn't run hot for "short periods" it's all the time, every day over 220
Well, thanks just the same
Last edited by MLPearson79; 03-14-2011 at 11:48 AM. Reason: Disrespectful comment removed.
Agreed, both on antifreeze and that the pressure raises the boiling point. Just like in the olden days of pressure cookers.
Kimolaoha
07-05-2023 01:04 PM
07-16-2020 12:54 PM
tylewis
08-18-2015 06:53 AM
PSIChocolate
08-13-2015 12:46 PM
08-12-2015 01:24 PM
