R56 Comfort Access and key
Anyone know if it's bad to leave key fob in the car when parked?
I keep the Minis in a locked garage and like to just drop the the "key" down in the cup holder so next time I just hop in and the key is right there. Nothing in Mini manual.
With that said my last Nissan had the same type system and the manual did say not to leave it in car as it was harmful to the cars ignition and drains fob battery. The proximity deal I guess.
Tanks-o-lot
Tanks-o-lot
Glad to hear this. I leave everything in my car, but have been bringing in the key to the new MCS since I got it. I'll go back to leaving it in the car in the garage now. I live on 12 acres and have a 1200 foot long driveway, and we currently have 8 German Shepherds in various stages of K9 training, so anyone who can get close to my car when it's in the garage is going to have to work at it .
Annette
Annette
For all those that do leave their fob in the car great news that you have a locked garage or safe place for it.
But if you do not have such a place to leave it leaving teh FOB in the car is the worse thing you can do.
Of note to many of you With Comfort Access you are not supposed to be able to lock the car with the fob inside. This has been proven on 07 thru 10 models where a fob is left in the car and the door button pressed and the car locks and immediately unlocks. Not sure if anyone has tried it on a 2011 but it is probably the same.
So to the OP yes you can leave the FOB in the car but it may drain the battery prematurely. As the Comfort Access FOBs have replaceable batteries if it does drain it there really is no danger just that you may need to replace the battery sooner.
I have had my fobs since April 2008 (almost 3 years now) and have never had to replace the battery. But then I never leave the fob in the car either.
Comfort Access UPGRADE ?
I recently bought a 2009 Mini Cooper S and I was disappointed to see that my doors do not unlock for me and my car only starts with the thingy in the dash. So how can I get the comfort access upgrade? Is it easy to install and how much $$$ am I looking at?
I don't live near an actual Mini Dealer.
Joe
Joe
Joe
Joe
Each door has has a little lock/unlock button on the exterior door handle.
(The doors do not lock/unlock without pushing a button - either the CA button on the door handle or FOB button).
There are radio receivers modules in the car. One around the rear view mirror area and my Clubman has one under the rear bumper. Maybe others elsewhere?
I believe the ignition switch cradle is different?
The FOBs themselves are different and very expensive.
Then there is programming the computer system.
Don't know if other associated wiring and connectors are present for all the CA electrical parts?
too bad...I would have loved the comfort access option. Is it possible my car has the option and it isn't turned on or I don't have it programmed or just don't know how to use it? Is there a way to know for sure by the look of the key or something? I bought my mini from a non-mini dealer, so they were in the dark about what options my car actually had and now so am I. It was advertised as having the premium package. I thought the comfort access was part of that package. I also thought the 10 speaker sound system was part of that package. Now I'm thinking the car dealership just used the word premium, not knowing that is was actually a specific mini package. Any suggestions on how I can be sure if my mini has the comfort package without driving to a mini dealer?
Also the CA key FOB has a pop off cover on the back for replacing the battery.
(The non CA FOB has non replaceable rechargeable battery that is charged by putting the key in the ignition slot).
There is a guy on the forum who works for a dealer and will run your VIN to see what options your MINI has.
Edit Look here:
https://www.northamericanmotoring.co...r-car-has.html
Also another interesting tidbit/misconception. Placing the key in the dash holder doesn't charge or in any way connect to the key to the car. It is just there for convince/aesthetics.
I also have been leaving mine in my car for about 3 years and still haven't had to change the battery.
One caveat: I get so used to it being in the car that when I do forget and bring in my pockets I almost always forget it next time and must run back upstairs to retrieve it.
Interesting anecdote: Once I left it on the A-pillier (outside the car) and it started. I drove 5 miles to work. Went into a panic not able to find it. Got out the car and it was right where I left it. I guess being that close to the interior "fooled" it into starting.
I thought the CA key FOB had to be in the slot in order to program it with the OBC settings?.... Also I was told by dealer to put the key FOB in the slot on the way to the dealer so the maintenance data would be transferred to the key FOB, otherwise no data is transferred.
Tanks-o-lot
Tanks-o-lot
Where do you live?
1. CA cars - the fob has to be in the slot to properly program the key for things like personal radio stations, blinker blinks etc. - But yes the CA fob "Does Not" have a rechargable battery. It also needs to be in the slot to get the latest mileage and run data for the car so that the dealer can scan it for a service appointment.
2. Non CA cars the fob has to be put in the slot for the car to work.
Comfort Access is a $500.00 factory option. From what others have said before. It's not possible / feasible to add later.
yes they are
yes $285 or more
And programing would have to be done after all the proper hardware was installed.
Can it be added to a Non CA car - simple answer yes but the cost would be out way to much. it would be much cheaper to seel the car and by one with it from the factory.
Tanks-o-lot
Tanks-o-lot
If you know of any online dealers that are good please post the link too. Thanks all.
The $450 is probably the key and the labor to do the programming - still high, I agree, but you can't compare it apples-to-apples to just buying the key.
The buttons worked and it would start the car when placed in the cradle like a non CA fob.
Had to go to the dealer and have the lost CA key un-programmed and the new CA key programmed into the system.
Maybe you can not have the programming and save some money? I am guessing $100-150 for the programming?
gar56
11-15-2016 06:41 AM
newminijcw
10-21-2015 02:37 PM
Emnotek
09-29-2015 07:37 AM
