R56 Can the alert bell/chime be changed/reprogrammed?
#26
#27
I don't think you can change the sound, I have had my car coded, we deleted the sound, changed the my hazard light to flash the Euro way, remote up the windows from the key fob, 1/8 tank of gas light on instead of 1/4...you can do so much but you literally have to learn German cus the car comes coded in all German once you get into it. I would highly suggest leaving it to the pros at dealer if you can make friends with the a tech that knows how not to leave anything stock ! Good luck.
#28
Thanks to some forum users (this forum) and to some weeks of internet researching about it , it seems the sound difference is because there is a different HU (Head Unit).
The only two (2) ways I can see:
a) Change the HU to a new one (mmm, no, thank you)
b) hack the sound file/config on the actual HU (not possible through NCS, surely something related to a writing/modifying the correct chip on the HU)
Now, seeing you mods list:
deleted the (seat belt) sound
delete this warning is not an option for me
nice! I never do this change because still I don't know if it's legal in my country. But again ... nice! I like the look.
Done some years ago! It is not acceptable that this function is not programmed "YES" from factory. May be there is due a countries law (that said my Mini shop tech The life is easier with this option activated
That's is not in my papers! If you have any info for the module and the variable to modify this, it would be great for me. I did not know this is possible.
Why entering in panic for fuel if I have stile more than 60 miles to go?. I prefer your choice (panic at 30 miles ).
Thank you very much for this information!
#29
May be related to KOMBI parameters?:
TANK_RED_REICHWEITE
wert_01
TANK_OHM_FEHLER_UG
wert_01
TANK_OHM_FEHLER_OG
wert_01
TANK_MITTLUNGSZEIT
wert_01
TANK_SICHERHEITSFAKTOR
wert_01
TANK_BERUHIGUNGSZEIT
wert_01
TANK_SCHWELLE_RESERVE
wert_01
TANK_RW_WARNUNG
wert_01
TANK_SCHWELLE_AUF/AB
wert_02
TANK
wert_02
TANK_VOLL_ERKENNUNG
wert_02
TANK_FILTER_STEIGEND
wert_01
TANK_FILTER_FALLEND
wert_01
TANK_RED_REICHWEITE
wert_01
TANK_OHM_FEHLER_UG
wert_01
TANK_OHM_FEHLER_OG
wert_01
TANK_MITTLUNGSZEIT
wert_01
wert_01
wert_01
wert_01
TANK_RW_WARNUNG
wert_01
wert_02
TANK
wert_02
TANK_VOLL_ERKENNUNG
wert_02
wert_01
TANK_FILTER_FALLEND
wert_01
#30
#31
