R56 Is there any way to copy the settings from one key to the other?
Since a lot of the driver's preferences are stored on the key, it would make things a lot easier if both keys had the same settings stored on it. Is there a way to copy the settings over? I didn't see anything in the manual about this.
I assume the 2011 is like the 2010 as far as fob settings are concerned. If that's the case, all you have to do is put your other fob in the car and go thru the drill in the owners manual to set the spare fob to your preferences. If you have comfort access, the procedures may be different. If you're near your dealership, you can just drop by and let your friendly salesman take care of it for you. Good luck.
AdrenaliNate
08-24-2015 12:37 PM
Ambient Thermal Management
08-07-2015 12:27 PM
