R56 Sunroof Question
Sunroof Question
Hello! Brand New Owner and Brand New Member!
I have a question about the sunroof...Ive seen various posts about the sunroof not working and getting stuck open. There is a tool to close it manually...the question is, where is this tool and how do i close it manually if I get this problem. I have a 2008 MCS. I already looked in the tray under the rear boot and dont see a tool Id use to close the sunroof nor do I see where it would fit.
Thanks!
Thanks!
Thanks!
Thanks!
Looked at my '10 Clubman. I popped off the plastic cover as shown in the older owners manuals. (Cover has airbag light and color LED's).
There is a ~ 0.75" hole in the black plastic part. Above the hole is the drive motor. In the center of the motor there is a hole that fits #20 torx driver. (The larger of the torx on the included screwdriver tool). You have to pull the driver handle part way off in order to have enough reach.
I inserted the torx driver and ran the sunroof with switch and the driver turned with the motor. I did not try to turn manually because I did not want to break something, but I would try it if my sunroof ever gets stuck open.
I am not sure you could turn it with the included screwdriver torx tool. Might have to use a large allen type or 'T' handle torx tool or maybe even a drill motor driver.
Thanks!
Thanks!
Manny_cooper
09-03-2015 05:48 AM
Interior/Exterior Another hood stripe removal thread
broncobuddha
09-01-2015 06:32 PM
