R56 Dremel holes in hood scoop to reduce engine/turbo heat: Good idea?
I have installed a Way Motorworks heatshield: Is it a good idea to put some holes in the air scoop to allow more air into the engine compartment to reduce some of the very excessive engine/turbo heat? ~Curious. Thanks. Nick
Water is going to get in there no matter what you do. I've just made it so more air can get in to cool everything. I have a high flow intake too, and more rain getting in hasn't affect anything either.
Opening up the scoop will allow some outside air to flow thru the engine bay which is a good thing. However, the biggest thing it does is to allow scorching hot bay heat a way to get out of there when you park. The total lack of venting that heat is what was causing scoop melting and hood paint discoloration. I've run the JCW CF scoop with no grill for 2yrs and had no real problem with debre that a damp cloth couldn't take care of. If you're running an open CAI then rain could be a problem.
I had a scoop warp on my '09 pretty quickly after I got it. I got it replaced under warranty and then dremeled the holes out and 8 months later no sign of deflection, most of the time is has been covered in Plastidip too. On a cool morning or light moisture after a hard run you can see the steam rising from the scoop when parked like a dragon ready to breath fire.
https://www.northamericanmotoring.co...381-post2.html Just follow his directions
Mini-Fini:
Black powder coated SS: http://www.minifini.com/ShopDetail.aspx?id=64
Natural Stainless Steel: http://www.minifini.com/ShopDetail.aspx?id=60
This is what I just bought. Now I need to open up my vents in the scoop.
http://www.minigenuineparts.co.uk/mi...lengeVent.html
I bought a ALta air filter. the instructions said remove the scoop and take out the insert that is blocking fresh air into the compartment. i am thinking of removing both front grilles to get more air in there.. OH, for the guy that was worried about water.. the motor gets wet when it rains.. my mini almost floated away a few weeks ago.. water coming in the doors..
07-16-2020 12:54 PM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
01-02-2018 07:26 PM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
08-11-2015 06:06 PM
O4mcs
08-10-2015 10:22 PM
