R56 Knocking under accelaration
If you have been using the same fuel right along and this is a recent event, I may go further for a solution.
How old are the plugs ?
Maybe a bad plug coil ?
Haven't seen many knock sensors go so I would check that last.
When I had an unexplained knock issue turned out to be my DME.... $$$$$$ eventually
the whole thing went south and I had to buy a new one...
Do you have an S or a JAC ?
Id pay the money to get a diagnosis and then if its easy enough fix it yourself. Is it a true knocking noise or is it more like a thumping or ticking noise? Coils or plugs would cause a check engine light to come on. And i believe predetenation from lower grade fuel would also cause a engine light.
I have this 2... I need help!!! Knocking occurs between 2nd and 3rd and anywhere between 3000-4500 rpm. My car has 45000km. In this time I've had to replace O2 sensor and fuel pump. Greece in general has really bad gas. To give you an idea a shell station next to my house had to get rebranded because of the poor quality that was being used. According to MINI the issues i had were all related to that station. I also have a problem with oil consumption (1 lt per a week which is ridiculous!!!). I'm wondering if this issue can be related... PS my exhaust tips are entirely black, so I'm wondering if that's from the same issue?
I don't know all I know is in a month i drove 500km and I put in 8 LITERS OF OIL and I'm freaking out!!!
riff42
09-22-2015 03:07 PM
MasterShaftner
09-04-2015 03:52 PM
