R56 Towing the Cooper
You shouldn't have any issues towing in this fashion. I'd carefully attach safety chains to the front suspension components or other nearby frame components. I don't thing using the tow hook will provide enough in the way of attachment points. Just don't crank down on the chains so much that you bend something. Should be easy peasy! Good luck at school.
And thanks for the pointers everyone, off I go
Yikes be careful with that crummy uHaul dolly. I moved once with a uHaul truck and the same dolly... towing coincidentally a dark green metallic Ford Focus ZX3. I wish I had picked the slightly more expensive trailer that put all 4 wheels off the ground.
FYI you cannot back-up with that dolly attached... I very nearly got stuck in a parking lot 2 blocks from my new apartment.
Hahah, someone else mentioned this to me too, that would DEFINITELY get some looks
Ouch, yea, everything went pretty smooth towing but I probably wouldn't use it again.. explained later
Thanks!
I'm at RPI, when I bought my MINI I only saw maybe one or two more on campus, this year there's like 8 or 9, wonder if anyone is on here.
I will definitely use it next time, I made it mostly fine. When I pulled away from my house the alarm started going off, it thought it was being stolen hah. But I just left it unarmed for the majority of the trip. My only issue came with when I took the car off the trailer and drove it to its parking spot. I got a warning that said ABS Malfunction and now I have a check engine that's pulling P1776 and P1777, which I think from looking around are related to the ABS speed sensor So I'll have to bring that by the dealership to get it checked out.
Thanks!
Hope you made it fine. I always use their 4 wheel dolly because its much more secure and comfortable to tow around. I'm sure you didn't have any problems but usually anything that takes longer than an hour I'd make sure to get the 4 wheel. Must be nice to have your car at school
09R56
11-16-2022 10:49 AM
theateist
08-22-2015 06:58 AM
BlimeyCabrio
General Mini related Ads
08-12-2015 06:04 AM
