R56 How to Replace the Map Lights?
Old 09-22-2011 | 12:16 AM
blitzed310's Avatar
blitzed310
How do you remove the lens cover on the map/reading lights to replace the bulb? I felt like I was going to break it when I tried to pry it with a flathead, the whole toggle switch assembly started to separate when I was doing this?
TIA
Old 09-22-2011 | 08:40 AM
Mach V Dan's Avatar
Mach V Dan
Slide the cover directly sideways (use your hand, not a tool) toward the outside of the car. It'll pop loose.
--Dan
Mach V
Old 09-22-2011 | 08:51 AM
blitzed310's Avatar
blitzed310
Awesome, thank you.
Old 09-22-2011 | 12:49 PM
10Zero's Avatar
10Zero
And I found getting the bulb out is quite the chore too. After trying a dental pick, plastic tipped tweezers, etc...I ended up using a strip of duct tape. Stuck the duct tape to it, wrapping it a bit, and pulling straight out. New bulb (LED) inserted using a piece of 1/2" vinyl tubing, bulb pressed into the end of it and inserted. Once there was some tension, twisted the tubing to remove, then pressed the bulb into place.
Worked for me...
Old 06-18-2017 | 12:58 PM
malibujoey's Avatar
malibujoey
yeah thank for that. I was perplexed too. Wanted some direction and not brute force and $50 bill with Mini to replace.
Old 06-18-2017 | 06:33 PM
malibujoey's Avatar
malibujoey
yeah. That didn't work.
Alkaidovich
01-30-2021 02:35 AM
07-16-2020 01:54 PM
12-23-2015 11:36 AM
danielbrookes_9
10-03-2015 01:51 PM
