R56 LED Side markers from OUTMOTORING / elsewhere. anyone have installed?
Hi everyone!
Just wanted to know if anyone has fitted these LED side marker/repeater lights to their MCS?
something like this!
http://www.outmotoring.com/mini-coop...er_lights.html
And this.
http://www.youtube.com/watch?v=qA-1h...eature=related
Im thinking of ordering it but wondering if anyone has personal experience/pictures to show! is it good quality? etc?
i'm probably ordering from outmotoring!
Do give me opinions! thanks! :D
And this.
I did have a set or I should say I have had 2 sets. The LEDs are great but the clips are below standard and they break easily. After the last set broke I said the hell with it and I am not getting them again. But if you get them the LEDs will not give you any problems its just the plastic parts.
Just got a set from Out Motoring for my R53 - and yes their fit is a bit loose ... I put a little double back tape on and they seem to stay on fine (but I just got them).
Note I did have the LEDs (for the R53) from Moss ~ got them a few years back ... problem was that they were installed only with double back tape and that caused problems for me when the connections (to the bulb socket) failed ... removing them was not the easiest ... Moss provided another set ~ excellent customer service ... but one just failed again - so I went to the Out Motoring units ... which at least should be much easier to remove & re-install (just like the OEM set up) ... even with the little bit of double back tape I used ...
agree that the LEDs will most likely never fail
do you get a lights out signal on your dashboard?
Note I also have LED license plate lights and they work fine ~ no warning lights on the dash from that
and no flickering or too rapid of blinks from the side LED turn signals either ~ synced blink pattern is the same as the rest of the turn signal lights
FWIW ~ I like the look of the Out Motoring side LEDs - the lense has a nice, subtle union jack inlay ~ at least the units OM offers for the "older" R53 do
PROBLEM installing LED side marker lights from OUTMOTORING, pls help!
HI! i have a big problem! i ordered these LED lights from outmotoring!
they came all fine but i have no idea how to install them? it might be quite silly but i dont know. the connector on these new LED lights are different. they look like this.
whereas the ones i have which are OEM on the car look like this...
http://imageshack.us/photo/my-images...54vp7.jpg/sr=1
how do i like, make it fit? :x
can someone who has installed them or someone who knows please help? :D
Main dealer can do it but won't and would charge a lot of money if they did. There are some good independent coders who can do it for you. Alternatively if you are very computer literate and very patient and willing to invest many hours and buy a special cable you can do it yourself. All the information is on these forums.
on
I've replaced almost all my bulbs with very bright ones from v-leds.
They were expensive but they are 4X as bright. I don't get bulb out
indicators.
Of particular interest to me was the brake lights. The v-leds fills the lens much
better and is much brighter than even those hyper bulbs.
You want to get the color of the lens.
indicators.
You would need to get the cold and warm bulb checks coded out by a someone who knows what to do. All external bulbs on an R56 Mini are checked Cold when you start the car and then checked Warm when you use a bulb and the car is running. LEDs use less current and consequently look like a fault, so the best way to use LEDs is to stop the car from carrying out these checks.
Nor does it take many hours.
I coded 5 options last night and it took 15 minutes.
Yes, you have to read the wealth of pdf's here (or 1) and proceed slowly.
The cable is ~30 bucks.
If you need help coding I would love to share info. A member here has received countless emails from me, but once you wrap your brain around it, the process is surprisingly simple.
Take advantage of nutsofamily's kind offer. , it will really ease the potential pain.
The actual coding time is not long, but it can take many hours to get a working system up and running from scratch. Not trying to put anyone off here, but there is a high level of perseverance needed and it will really help if you are comfortable with computers at a programming level. Many struggle and the forums here are full of help requests.
Once I purchased a working cable, everything fell in place.
I will be posting a step by step code for the sport button with pictures soon as well as a simple code step by step.
For me, it was a few simple steps that may have seemed obvious to others that got me hung up. After all, we are talking about the computer
07-16-2020 12:54 PM
squawSkiBum
10-02-2015 09:21 AM
cm.d
08-19-2015 08:51 AM
