R56 what kind of oil filter and engine oil do you use?
#51
The MINI-branded oil *is* Castrol, but I've never had any luck finding the same formulation at local stores. The MINI oil meets the ACEA A3 specs and is BMW LL rated, while none of the Castrol I've found in stores meets both specs. There's a "German Castrol" out there that some people have found in local stores that meets all the same specs as the MINI oil, so I think that's the particular formulation that MINI is rebadging.
#52
You should read http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
The only way you can "screw" up an oil change is not putting in a correct filter and not ensuring there are no leaks. Otherwise, you can put 20W50 in that car and while it isn't the "designed" oil for the engine they cannot void your warranty.
Dealer: I'm sorry, we're not going to repair your engine under warranty because you're using Nology spark plug wires and a non CARB-approved cold air intake.
Customer: But the engine failed from lack of lubrication - those mods aren't even related! The Magnuson-Moss Warranty act says you can't deny warranty coverage unless you can show that my modifications caused the problem.
Dealer: I'm sorry sir, but we're not honoring the warranty claim.
Customer: But..but...bu - MAGNUSON-MOSS!!!!
Dealer: Sorry, if you want to go any further, you'll have to sue us. See you in court. Hope you have lots of time and money lying around!
#53
#54
The problem with the Magnuson-Moss Act is that it has no teeth. In theory, the dealer/manufacturer should have to conclusively prove that the damage/failure resulted from your choice of parts or materials before denying a warranty claim, but the reality is that you can't force them at gunpoint to honor a warranty claim. When M-M is brought up in the real world, the conversation usually goes something like this:
#55
MINI branded oil over here should be LL-01, not 04. 04 is designed for low sulfur fuels which we don't have here in the USA. So the oil you get at MINI should be rated for the USA. Either way it is rebranded Castrol but that doesn't mean that it is the best because MINI uses it, it is just a deal that was struck between Castrol and BMW.
Sinistershade (10-11-2017)
#56
I mod my cars too, but at the end of the day, if you're hoping to maintain warranty coverage, you have to think about what mods you're willing to make, whether or not they're easily reversible, how your dealer views aftermarket modifications, and whether or not you're providing your dealer with an easy excuse to deny coverage.
Relying on the MMWA to somehow force the dealer's hand in a warranty issue isn't going to get you anywhere.
#57
I didn't specify either LL-01 or LL-04, simply because I don't have a bottle of the MINI oil here at my desk. My point was just that even though the MINI oil *is* rebadged Castrol, that doesn't necessarily mean that you can walk into Wally World and buy the exact same stuff for less (or at all).
#58
Here is a link to MINIs list of approved oils, you have to scroll down a bit to see it.
http://www.miniusa.com/faq.jsp?categ.../maintenance-m
Amsoil is not on that list.
Disreputable dealers have denied warranty claims saying that the owner didn't use "Top Tier" gas. I'm not saying that it is the right thing for them to do, but some do deny claims for stupid stuff like that.
It's just so much easier to put an approved oil in the car and avoid a lot of grief from a dealer, who is looking for an excuse to deny a claim.
Besides, Amsoil can't possibly be that much better than any other premium synthetic oil. I'm not saying Amsoil is bad, it is probably very good, but I skeptical that it is more than incrementally better. So, for me, it is not worth the potential hassle.
Dave
Dave
#59
Sometimes is can be pretty obvious to the dealer that you're not running the MINI oil. For a while, I was using BioSyn RLI 5W-30, which is a plant-based synthetic oil. It doesn't look or smell anything like petroleum-based oil, so I was taking a chance and betting that I wasn't going to have any unrelated engine problems while I was using it.
Another interesting thing about the M-M Act is that a manufacturer CAN make the use of THIER consumables a requirement for warranty coverage, as long as they provide the consumables at no cost to the purchaser. So, if MINI ever wanted to be really snotty, they're within their rights to force you to use their oil and filters in order to maintain warranty coverage, at least during the 3/36k maintenance agreement where they're doing the oil changes at no cost. I'm not saying they'll ever do it, but it's there in the M-M Act.
#60
As far as the MM is concerned let's just let it go. I didn't bring that up and really don't care. I agree that leaning on the MM is a bad idea anyway but I have yet to hear of any dealer denying (even disreputable ones) a claim based on oil. Sorry, I ain't buying it and if your oil meets or exceeds the standards then you shouldn't have a problem.
As for what Dave posted, thanks for the link. If you continue to read it just below the list it CLEARLY states that you can use a Synthetic oil that meets or exceeds the API standard of SM and then states the "good stuff". So, you are not tied to using only those oil in the list, you need to read the entire paragraph, not just pull out what you think it means.
As I stated, use what you want. However, don't bash on something that you have no clue about. Motul and Amsoil are both great products and like I said I have seen a huge difference in both my high milage, raised on the autobahn vehicles.
#61
The spec sheet on Castrol's website lists German Castrol as LL-01. That's what I recall being on the labels as well.
#62
I haven't bashed Amsoil, or Motul. Until this thread, I hadn't even heard of Motul.
I'm just skeptical that they are any better than any other premium synthetic lubricating oil.
I won't jump through any hoops just to get an oil that I think is, at best, marginally better than the oil I can get at my nearby MINI dealer.
I really didn't realize that people could be so passionate about a brand of oil!?
I didn't mean to get anyone upset.
Dave
Dave
#63
Don't know about the stuff that is bought here as I never really bought any. However, the Castrol I bought when I lived in Germany was LL-04. I don't think that I saw an LL-01, however, I could be wrong. If it is LL-01 it is probably just rebranded.
#64
Dave
Dave
Trust me, I was skeptical at first as well until I tried it.
#65
Because your reasoning isn't founded on much more than B.S. that is why it is offensive. It reminds me of people who have computer problems and blame "the network" because someone told them green Cat5 cables are worse than white.
It is obvious you are sold on a bunch of retarded "formulations" which is nothing more than a scheme to get people who are naive to purchase that. Most companies aren't going to pay a company to "certify" their oil and for that I am happy because most car makers just use that as a scare tactic for the less educated.
It is obvious you haven't turned a wrench for a living in your life and probably haven't rebuilt enough engines in your lifetime from various conditions to understand how premium oils can protect the most commonly worn areas of your engine. To each their own...you can continue to purchase that "mini" relabeled oil and I will continue to keep using Amsoil and having my engine around for 200,000 miles like the rest of my cars.
Dave
Dave
#66
#67
Actually, I was a Lincoln-Mercury mechanic, until I went to engineering school.
I was hoping to get into the automobile engineering business, but instead got sidetracked to large industrial diesels. Such is life (sigh).
I have a small stable of British cars that I have restored, I love cars!
You can believe what you want, but really, the differences between between different brands of premium synthetic lubricating oils is insignificant!
Dave
Dave
#68
Dave
Dave
Having cars doesn't make you experienced with oils
Believing what you want may help you sleep well at night but that's all
If hospital A was slightly better than hospital B.....which would you choose for care? The difference might be insignificant to you but the engine feels it.
How many threads do I have to read that say the same thing. It's either "I believe" or "I think"....either try the product or provide hard core research against it. To be a productive thread it needs to be free of speculation is all I'm saying.
#71
Bottles of recently purchased Castrol EDGE with SPT 0W-30 European Formula (Made in Germany) show BMW Longlife-01
More info than most would ever care to know about oil (Hope you have plenty of time to kill ):
www.bobistheoilguy.com
www.bobistheoilguy.com/motor-oil-101/
www.bobistheoilguy.com/engine-oil-analysis/
#72
I think I'm going to use the fluid evacuator,liquivac
LiquiVac Small Engine Model (capacity 3 quarts) http://www.liquivac.com/buyonline
do you guys think it's enough capacity?
Liquivac makes another model that holds 5 or 6 qts that is designed for regular engines and it has a better pump to help remove any sludge.
#73
Dave
Dave
It meets the requirements in the first sentence after the specific brands listed. "Use only synthetic oils with an API rating of SM or higher". That qualifies Amsoil. Also I believe Amsoil has their own warranty that they will cover the cost of repairs to any engine that is damaged using their oil and is refused warranty service by the dealer.
I would also bet that you could enlist Amsoil to raise a lawsuit against Mini on your behalf if a dealer refused warranty service because you used Amsoil.
Also that list is different than what is in the Owners Manual. Mine recommends Castrol Synthetic 5w-30. This list only shows Castrol European blend 0w-30.
I'm not trying to talk you into using Amsoil. I am just saying that I would not worry about voiding a warranty as Amsoil does meet the necessary requirements to fulfill the warranty agreement.
#75
They don't... Most people just think there is a conspiracy. The most they will do is possibly send a sample out to see if the oil is bad or simply check to see if it is low. That is about it.
