R56 Seat-sons Greeings Teaser!
Seat-sons Greetings Teaser!
My g/f gets the thanks for santas early arrival... what would i do with out her. I have wanted these for so long and didnt take the plunge wheni could have and in return i got quite the surprise!
Teaser of one done, gotta wait to install the passenger seat due to the incorrect bracket i was given
No srs lights due to airbag...thanks to the motoring alliance write up.
The feel/feedback is amazing! BEST mod after suspension to really "know" what is going on traction wise. No body/core movement during G loads lets you translate the cars feedback so much better. VERY Much Recommended!
2011 Sparco EVO II
More to come later
2011 Sparco EVO II
More to come later
For me*... yes, perfectly snug but not too tight(evo 2's a a lil wider than the evo). Just gotta reset the srs light because i used the wrong resistor on the driver side... good thing i have my hook ups
We are upside down because now i want a downpipe and aquamist. Did you have to wait for the aquamist? When i called to place an order they had a 3 month wait so i decided not to.
I had started a group buy for the HFS3 over on the RMW forums, so id did take a while to get the minimum buy-in list filled and then to get everyone's kit built and sent out. That may have been why the wait at one time was so long.
it also generated a lot of buzz about W/M injection so suddenly demand went way up.
Maybe you had checked when Jeff was completing the group buy orders? I'd be surprised if the wait was still that long, although he mentiioned he sometimes has to wait for parts from his suppliers so that could also be the problem.
It's definitely worth the wait though. It's a top notch kit.
I still haven't had it tuned for meth. I'm just using the caned AP tunes and tweaking the W/M settings here and there guided by the butt dyno.
I'm hoping to get a RMW tune one of these days, but I haven't seen Jan planning any road trips to my area.
If so I definitely plan to get a custom tune. COBB tuning here was supposed to begin custom tuning MINIs but I haven't heard much about it after they announced it so I'm not having any luck finding someone to do a tune.
Edit* the address is at -m-o-t-o-r-i-ng alliance nam blocked it
http://www.*********************/for...exclusive.html
You will see a reduction in IAT, but how much will depend on what your ratio is as well as your jet size. It won't be a world of difference but it's something. I wanted it for safety reasons since I'm running higher boost. At least until I can get a meth tune...
Brey Krause R53 - 9273 (specifically for the EVO II) 9272 is for the regular EVO (narrower)
Just have to slot the holes of the rear part of the brackets about 1-2mm, Fronts line up perfectly. (tungsten dremel bit worked wonders).
Could probably do a seat in about 30min now
Ive need be i can slide the passenger seat forward enough to fit a slim person, rear seats going bye bye sooner or later though for the harness bar/roll cage
I thought that might be your next step.
I installed the Kappasphere harness bar recently:
http://www.kappasphere.com/mini/mini.../monkeybar.cfm
Nice addition and just waiting now to do the seats and then get harnesses.
Any pics
2011 Sparco EVO II
More to come later
2011 Sparco EVO II
More to come later
I need one more inch to be able to fit in a coupe.
