R56 Were any R56's pre-wired for OEM front fog lights?
I'm still on a quest to install front fog lights and have them wired to the toggle bank. I thought I read in some thread that some R56's were pre-wired for front fog lights. Is that true? Can anyone confirm and tell me what year or how I might check on my own car (i.e., is the headlight wiring any different?).
Also, is there coding in NCS Expert for enabling the front fog light toggle? Would it be Nebelscheinwerfer (fog light) as opposed to Nebelschlussleuchte (rear fog light)? If there's no pre-wiring, I'd be left with the daunting task of wiring into the existing harness/fuse box controlled by the computer . I know the easier route is to install them on a completely independent circuit like the driving lamps, but there's that one empty toggle...
Depends on the year if the wiring was there or not. 08 car (which i believe yours is) had wiring for just about everything. The one way to tell is by the connector on the "City (parking) Light housing. The difference between the two is the non Fog housing has one light and the Fog housing has fog at the bottom and City Light at the third.
So you would have to replace the fixtures and have it programed. But to be sure I would look at a car that has the fog lights and yours to see if the same wiring is there as on the fog light car.
Just an FYI thru out the years 07 to current there have been production errors and once in a while a few cars would come off the line missing something that all ohter cars had and even if it was not used. So the ONLY real way to know if you car has a specific item is to veryify it with a car that is known to have it.
If I'm not mistaken, the front fog lights son't use the toggle switchs belos the AC. They get a new dash trim part with the switch, just to the left of the steering wheel.
The rear fog lights use the toggles.
OOPS never mind, FOG LIGHTS not driving lights... Carry on, pay no attention to me...lol
Examine the fog light bulb socket to see if the wires are present.
There is probably a relay or empty spot for a relay somewhere like in the fuse box?
My '10 Clubman was ordered with front fog but not rear. All the rear fog light wiring and bulb is present.
My 2007 was prewired to the lights. The plugs were behind the foam behind the rear bumper. I just plugged in the lights then found the wires to the lights on the passengers side of the inside boot. Cut the wires and tapped the brake light signal. They act as running, brake and blinker lights.
I was excited when I read this...
Then I read this...
Thanks, but we're talking about FRONT fog lights in this thread. Still not certain if any years were pre-wired for front fogs.
Then I read this...
I've found something strange on my 07 cooper s r56.
It gives a dash warning symbol when starting the engine (looks like a dipped headlight) that apparently means the fog lights are broken. When I went to change the front bulbs I found the wire but there was no light assembly on the back of the lens! There are running lights or whatever they are called - the dim ones just to make you visible but where the fog light assembly is meant to be on the lower half of the lens there is nothing.
Whats going on here?! Can I buy the rear assembly to fit on the lens?
So you just have the position light option? 63172751293
https://www.northamericanmotoring.co...to-mini-s.html
If fell out, sometimes they separate from the housing? Do you have pics?
Ok, that makes sense. I thought you had an issue with the lights themselves.
part # ?
Part # to this light fog
The fog/position light housing part number is 63172751295 linked in the thread below
https://www.northamericanmotoring.co...ight-help.html
07-16-2020 12:54 PM
JHolland
08-13-2015 10:47 PM
