R56 Wired OBD2-to-Android
I was just reading another thread discussing use of the Torque app for Android, along with the KIWI OBD2/Bluetooth device, to stream engine performance data, read fault codes, etc.
Have any of you set up a similar system using a wired connection? Just curious... the KIWI hardware looks pretty slick, but costs $100. Seems that an OBD/mini USB cable would provide the same interface to an Android phone for a lot less expense.
Comments?
Thanks in advance,
Spridget
Comments?
Thanks in advance,
Spridget
Get Torque
http://torque-bhp.com/software/torqu...obd2-adapters/
and something similar to this,
http://www.cravenspeed.com/bluetooth-obdii-connector/
You can get them cheaper then this. Ebay and other places on the web.
Edit***
I saw where you were talking about Torque after I posted.
Edit***
Same as the one on Cravenspeed and I have this one also.
http://www.google.com/products/catal...28684309686673#
http://www.amazon.com/XITECH-BLUETOO.../dp/B003MQ89X4
http://www.google.com/products?q=obd...+adapter&hl=en
Thanks to the comments above... I just received a new Xitech OBDII-Bluetooth interface, and will be using it with Torque. I'm at work at the moment, and will probably spend my lunch break out playing in the car.
That said, I may also try to use a mini-laptop as well as my Android phone. Did you chaps use the software that came with your adapters (on mini-CD), or did you download something else?
Thanks!
Spridget
Thanks!
Spridget
on
Danny -
No kidding. This is definitely a neat alternative, and at a very reasonable price. The OBD/Bluetooth adapter was $21.09 from Amazon, and Torque was (as you know) $4.95. And it's Bluetooth, so you don't even need a cable. The original title of this thread may be misleading now... I was thinking "wired" at first, but eventually went wireless, and you can't change a thread title.
Spridget
Spridget
Which adapter did you pick up from Amazon for ~$20 and are you happy with it?
Danny -
Spridget
Spridget
This is the one I ordered:
http://www.amazon.com/XITECH-BLUETOO...=5336118863-20
As for satisfaction, I just got it this morning and have only had time to get it paired, connected, and tested for a few minutes. So far, so good, but time will tell. The developer of the Torque app seems pretty adamant that anything less than the Kiwi device @ around $100 may not work satisfactorily, but Porthos, just above, pointed me to the one I bought. It's the second link in Post #3.
Spridget
Spridget
