R56 Clunking from the undercarriage......help guys, I need direction/new owner....thanks
There are so many things it could be if only happening over a bump. some suspension parts gone bad, exhaust hanger missing, something stuck to the bottom of the car, and many many other things.
One thing i had was the plate on the bottom of the car that will hold up the exhaust if all the hangers failed. It has 4 screws in it an if they are all loose it can rattle.
No, stock 100% and it's not bottoming out. After searching it may be the sway bar bushings as it appears to be a common problem. The car handles well and I don't think it's the control arms but then again, I could be wrong.
Question, does this car have both front and rear sways? Anyone have the part no. for the bushings?
A dry swaybar bushing would make squeeking noises and you might feel the car handle differently going around turns since the bar would stick, and then move instead of moving freely. I do not think that's your problem. And yes, the MINI has front and rear sway bars.
Did you just do a search on NAM and Google? I would not go by this. You need to get the car on some jack stands and start checking things yourself.
I searched on NAM for clunking and swaybar issues popped up quite a bit. But you're correct, have to get down and dirty. I have a major tune up coming up so the timing is good. Changing oil to M1 0W-40, air and cabin filters, Redlin trans fluid, seafoam, installing catch can and boost tap and possible spark plugs and brake fluid if necessary.
