R56 Mini parts knowledge base
Are you familiar with gasoline turbocharged engines?
If so, there's not much difference on the Prince engines.
If not, pick up a internal combustion engines textbook and get to speed on the terminology.
Also, having RealOEM.com and a Bentley Publications service manual at your finger tips will certainly help.
- Erik
- Erik
Where are you starting from? What is your current level of automotive/mechanical knowledge?
For really basic things, www.howstuffworks.com has an automotive section that has lots of basic explanations and animations and such. (Like "how a camshaft works".) I personally cut my teeth on John Muir's "VW Idiot Book", which explains a lot of things about a very simple car (old-school aircooled VW Bug) in very straightforward language. Might be worth a look; just remember that things are quite different between a ~1940s-tech economy-minded "people's car" and a ~2000s-tech "premium compact" car.
If you're starting from more than the basics, then Erik's suggestions are very good.
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
