R56 Radiator fan always stays on after having water pump recall performed
#27
#29
That's been established. It was just coincidental that the rad. fan started running longer after his aux water pump (to turbo) was installed.
#30
So I drove over to my parents for mothers day lunch, drive was about 45 mins 1 way.
I kept an eye on the temp via that menu, temp was consistently in the 232-234 range. I think it's safe to say, that is pretty much on the high side and something is going on? Especially is "normal" is considered to be in the 220 range.
#31
#32
#35
#36
Just put mine on finally
http://www.minigenuineparts.co.uk/mi...lengeVent.html
and it seems that the fan is not staying on as long. I have only had it on for 2 days so I really can't confirm that yet.
#38
#39
So I have noticed that ever since having the water pump recall performed, the radiator fan is always remaining on after I shut down the car after a drive.
Now, I know that this is a design feature to aide in cooling once the car is off. In the past, I have only noticed it staying on maybe 10% of the time. Now, after the recall work, it seems that it remains on 90% of the time.
Was there also am associated software update that makes the fan stay on longer after the car has been shut down?
#40
I don't think it's a common issue with the earlier 2nd gens but they (temp sensors) have been failing on the 2010' and 2011's.
He'll get it.
#41
water pump or thermostat??
I'm having the same issue with something noisy running for a long time after having the recall work done. I can't tell you if it's the fan or the water pump or something else that continues to run, but it is loud and wasn't there before the recall work. However, I also had a leaking thermostat housing replaced at the same time so could it be something wrong with the thermostat replacement and not the aux water pump???
At first I thought it was normal since it made sense to me that the fan running longer would be the solution to the overheating turbo, but now I'm researching it is because my battery just died and I'm trying to determine if the fan/pump running for so long every time I go somewhere has killed the battery and needs to be fixed before it kills another battery.
It's quite possible that the battery was just at it's end, but seems odd that everything is gong wrong at once .... figures though, warranty just expired 6 months ago!! Is there a thread somewhere to tell me what to expect to blow next????
#42
One vote for an temperature sensor.Mine was bad,temps are under 90celsius and fan still runs 5-10 min after I was stoppet car.Easy fix,just take connector and locking pin off,pull sensor out of termostathousing,replacing new O-ring gasket and push new sensor on the hole. then bleeding the coolant system..
alistaircookie
10-08-2015 10:52 AM
gmonde
09-08-2015 06:37 AM
