R56 Has anyone done a DIY muffler delete on the hot side boost tube?
Old 11-20-2012, 06:35 PM
Papote's Avatar
Papote
Papote is offline
Originally Posted by Lazlo10S
I did this mod. I used this pipe:
http://www.siliconeintakes.com/produ...e64ac1a56f7d95
I figured pipe with heat sink > pipe without heat sink. Especially in the hose going into the intercooler. It probably doesn't help much, but if it helps a little it's worth the $40. Installation went slick as a whistle.
I have a 2008 MCS. It says 9" long, while most people do 8". Does it fit properly and with the factory clamps? Also, are the fins not in the way of other parts?
  #27
Old 11-20-2012, 06:52 PM
Lazlo10S's Avatar
Lazlo10S
Lazlo10S is offline
The extra inch didn't seem to cause any issues.
Yes it fits with the factory clamps.
No, the fins do not interfere with anything else in there. They are slightly less diameter than the oem muffler. And no need to worry about the lack of bracket to the radiator. There is very little movement in the hose once its all back together.
I did a writeup on installing it with pictures, well, links to pictures here:
https://www.northamericanmotoring.co...er-delete.html
Good luck and happy motoring!
jwmolmen
09-22-2015 10:00 AM
ltjpunk7
09-06-2015 07:32 AM
bleonard1401
08-11-2015 02:53 PM
bleonard1401
R60/R61 Stock Problems/Issues
08-10-2015 02:15 PM
jrezzo
08-09-2015 10:32 PM
Quick Reply: R56 Has anyone done a DIY muffler delete on the hot side boost tube?
