R56 Determing What Service is Required
The Mini says it needs service...but what service? The owner's manual seems to indicate that you can use the onboard computer to determine what service is required, but the information available doesn't match what the manual claims is available. The only things available through the onboard computer is to set the date and time. Is there a way to determine what service the CBS is saying is required?
Yep, that's the part I missed - had the key in, but engine wasn't running. It says I need brake fluid service. I thought they did that when I had it in to replace the water pump - maybe they forgot to reset it?
It goes something like this:
Oil change 1 year or CBS (CBS does not get reset at 1 year).
Brake fluid 2 years or CBS
Micro filter 2 years
Air filter 2 years or every 2nd oil change or CBS
Tires 6 years
Spark plugs 60K
Auto tranny sevice 100K
Oxygen sensor 120K
Coolant N/S ("Long-term rated. Change at system repairs ony").
V-belt N/S
Fuel filter N/S
Power steering fluid N/S
Tires 6 years
Spark plugs 60K
Oxygen sensor 120K
V-belt N/S
Fuel filter N/S
Kimolaoha
07-05-2023 01:04 PM
stevepsd
35
12-06-2022 03:22 PM
08-19-2015 12:51 PM
