R56 Want to make it as efficient as possible!
#26
Salve to Felines - Thank you for your remarks! I had been despondent for several hours thinking something was ...'wrong with you people' (me)! I checked my title as you did and I am, indeed, the owner of my MINI and today, enjoy driving and, well, you know... There is some insight here into this thread, in general on NAM. and what can be an enjoyable discussions and the helpful discussions that occur here. In the spirit of helpfulness perhaps others could share some hints into a path to not being 'whats wrong' ---- nutritional supplements, meditation, counseling,...
This forum is very enjoyable and most of the time there are well-meaning, helpful people to be found. Seems like there are others that have had a little too much caffeine or, perhaps need to add some fiber to their diet...
I intend to stay here and do a better job of ignoring some of the 'rants.'
There is always room for improvement and additional civility. I hope.
PS - I am looking for a new cat and begin again to be another Salve to Felines!
#27
When you inflate street tires more, you gain lateral grip and better transient response, because the sidewalls are stiffer. You do apparently lose some braking and accelerating traction, but not a lot from what I can tell. I have done testing on this, and several others that I know have also done testing. Grip does fall off again as you go higher, especially on bumpy pavement, but the pressures this happens at seem to be at or above the max pressure on the sidewall.
Michelin - http://www.michelinman.com/tires-101...Name=Scalloped
BF Goodrich - http://www.bfgoodrichtires.com/tires...%20in%20Center
Bridgestone (page 8) - http://www.bridgestonetire.com/PDF/G...arranty_EN.pdf
Cooper - http://us.coopertire.com/CooperTires...lletin_105.pdf
Kumho - http://www.stylintrucks.com/Articles...rPressure.aspx
Now, I'm not saying that anyone has to do anything that they are uncomfortable doing. However, increasing tire pressure is a known way to cut down on rolling resistance and increase fuel economy, and the problems that people cite are either exaggerated, or only problems with 30-year-old tire tech, or are flat-out wrong.
#28
Holy fuel economy, Batman! Some people get so worked up. I think the whole point czar was trying to make was to not worry so much over every last mpg and just enjoy driving the MINI. You're right, it's your car, your name is on the title, blah, blah, blah. My name is on my title too (well, the bank and me...). There are cars built to play the fuel mileage game, such as the Prius, Volt, Cruze Eco, etc... Nobody says you can't do it with a MINI, you certainly can. The idea though is to enjoy the MINI for it's driving experience.
When I started my "new" car search, I initially had fuel economy as a high priority. I was looking mostly at the Mazda2 and Honda Fit. But my plans quickly changed and I focused on the MINI. Wound up with my MCS. Fuel economy was still on my priority list, but I knew I'd sacrifice a few MPG over the other cars, including a base Cooper. Choice I made. Do I try to squeeze good fuel mileage out of it? Absolutely. But do I sweat it if a tank got me 34mpg instead of 36mpg, and I enjoyed hitting the boost here and there? Uh...lemme think...NO.
BTW, I agree with schatzy's post. Over inflating tires is really not much better than underinflating. It has it's own set of problems.
#29
The contact patch may shrink slightly, but the sidewall stiffness still improves the cornering grip.
again to a point this is correct but an over inflated tire running on the center of the tread generates overheating in the center of the belts and causes different movement of the tread in the center compared to the outer edges and causes creeping of the belts and premature failure.
Tires inflated above the auto maker's recommendations do not run on the center of the tread. I ran multiple sets of tires to the wear bars and beyond at 50 PSI. The tires wore almost perfectly even across the tread.
Again they are not experts on tires and are they really sure they have the pressure they state they have in their tires.
... over inflation causes many issues with tires such as being able to be punctured easier, more sever damage on impact, harsher ride, faster tire wear, handling problems and other issues.
The tires do not wear faster at higher pressures--in fact they appear to last longer. They are subjected to less heat and less tread squirm than tires at the auto maker's recommended pressures. Check over on http://www.cleanmpg.com and you will see that many people over there have experienced longer wear from tires with pressures near (or over!) the pressure listed on the tire sidewall.
alex87f
03-25-2017 03:46 PM
minipopkart
08-13-2015 05:22 AM
Ambient Thermal Management
08-07-2015 12:27 PM
