R56 Alta Positive Steering Response System (PSRS)
If you want to spend the day dropping out your entire front sub frame, removing the swing arms, getting the metal cylinders welded to said swing arms (more $$$) and then getting everything back together. The set screws supplied don't really hold well, even with some locktite, they tend to just grind away at the hex arm on the swing arm, making it loose. After trying to fix it a few times, I just took them out and put PowerFlex bushing in.
07-16-2020 12:54 PM
