R56 Question about bent radiator fins.
I'm sure this may have been asked before at some point. Today I was installing my new Forge intercooler on my 2012 MCS. After I was done I stood back to admire my work, then I notciced that I had bent some of my radiator fins (DOOP!!) I guess the back of my hands pressed up against the radiator some during the install. Those fins are delicate little suckers. My question is this. Is this anything to worry about? I took the car out for my post install test run. The water temp never got above 222 on my scangauge and it was 100* outside.
you're likely to do more damage by rebending the water passages (cracking and leaking) than what a miniscule loss of airflow did to reduce cooling. you'd have to have folded flat and sealed off a huge surface area to seriously affect cooling efficiency and your temp measurements indicate that no discernable loss has occured.
R50/53 More supercharger hulabaloo
one73ronin
23
09-22-2015 09:56 AM
09-11-2015 01:15 PM
